TOO COLD
Flooi
Closest Airfield: Fahg
Has thanked: 103 times
Been thanked: 57 times
TOO COLD
Unread post by Flooi »
My gen 3 2200 with 260hrs is running too cold. After climbout at cruise oil temp is hardly at 60deg. All else in green...... any ideas or suggestions?
Hennie van Zyl
T4flyer
Been thanked: 11 times
Re: TOO COLD
Unread post by T4flyer »
Hi Hennie,
Fit a TCOA. Your welcome to come see my installation, I'm hangared at Springs (FASI).
https://avcom.co.za/phpBB3/viewtopic.ph ... a#p1586643
Cheers, Don.
Has thanked: 2056 times
Been thanked: 2124 times
Re: TOO COLD
Paul Sabatier
ZuluBen
Has thanked: 32 times
Been thanked: 16 times
Re: TOO COLD
Unread post by ZuluBen »
Hallo Hennie.
I put duct tape over half of the oil cooler till summer
Closest Airfield: Tranquility
Has thanked: 746 times
Been thanked: 1700 times
Re: TOO COLD
Unread post by Chalkie »
Flooi wrote: Fri Jul 24, 2020 5:07 pm My gen 3 2200 with 260hrs is running too cold. After climbout at cruise oil temp is hardly at 60deg. All else in green...... any ideas or suggestions?
Hennie van Zyl
Hennie, if an instrument gives strange readings; suspect the instrument (and the transmitter) first.
My advice, before you do anything else. Dunk the oil temp sensor (connected to gauge/EFIS) in boiling water: if you get about 95*C in Nigel, that would be about right.
If gauge is accurate, fit the thermostat to control temperature.
