That SOUND, That WHISTLE, Those GUNS...
- Too Tousand
- Has thanked: 802 times
- Been thanked: 1756 times
Re: That SOUND, That WHISTLE, Those GUNS...
Really looking good. Awesome...
- These users thanked the author Chalkie for the post:
- Little Friend
- 10000 and still climbing
- Closest Airfield: Mossel Bay
- Has thanked: 1337 times
- Been thanked: 1880 times
It is going to be a stunner! Love it.
- These users thanked the author Whirly for the post:
- Little Friend
- 8000 Tousand
- Closest Airfield: FACT
- Has thanked: 100 times
- Been thanked: 883 times
WOW, she's looking even better than I imagined!
- These users thanked the author Deanw for the post:
- Little Friend
- Closest Airfield: OR Tambo
- Has thanked: 3357 times
- Been thanked: 1099 times
Just plain WOW
- These users thanked the author Ray W for the post (total 2):
- Little Friend • mike.allaway2
- Pre-take off checks
- Closest Airfield: FALA
- Has thanked: 3 times
- Been thanked: 35 times
She’s awesome! Upgrades adding to her safety and will make het the best around!
- These users thanked the author Skyline for the post:
- Little Friend
Whatever you do in life, Knots count!
- Stratospheric Poster (> 40 000 posts)
- Has thanked: 1067 times
- Been thanked: 5073 times
Time for an update please
- These users thanked the author Bearcat for the post:
- Hammer
- Fuelling up
- Closest Airfield: HKIA
- Has thanked: 16 times
- Been thanked: 54 times
Mid year 2022 UPDATE!!!
Team RCA are in full steam ahead mode, pushing for an August roll out... The amount of time taken to establish clear system locations, failure points, dual/triple redundancy options, testing, etc... goes along way in keeping this brute of an aircraft and it's crew/pax SAFE!
All panels have been pre-fitted, we're now completing the final systems installation including avionics (screens arrived from Dynon), 80% of the way! Next will be paint shop, fitting custom seats and onto the rollout for test flying.
Firewall Forward
Systems
As a matter of interest, the current design setup is safer and contains redundancy that's far superior than the manufacturer (Titan) build file.
Avionics
Thanks to all those for their PM words of encouragement or questions I've answered which I thoroughly enjoyed engaging in.
Until the next update! Have a GREAT weekend
Firewall Forward
- Cowling - Custom scoop vents added for cooling (mount scrubbed up on cowl, added the cooling feature as a recovery)
- Cowling - Custom cnc'd frame, installed around manifold
- Cowling - Dipstick panel/access panel to rear engine
Systems
- Under forward section of fuselage - Dual fuel pumps, fuel flow sensor, solenoid, water cooling pipes, over flow hydraulic brake fluid
- Rear fuselage - Batteries (one located in the tail as backup and the other further forward), hydraulic pump, OONO reverse relay module, pressure sensing probes for up/down on gear, engine bridge hydraulic gear pressure system config, relay switch on the hydraulic pump (prevent a hyd pump burn out situation), starter solenoid.
Avionics
- Rear panel - Taking shape
Whistling Guns
- Has thanked: 1949 times
- Been thanked: 2177 times
Looking awesome
While you are busy add an external power connector. As CB50 has enough capacity to crank the engine and charge the battery.
Paul Sabatier
- Fuelling up
September 2022 - Final Countdown
It's time for a New update. Progress may look slow but believe me the time it's taken to complete most systems and shave the sharp edges with a final polish is well worth the wait! "90% done, 90% to go"
- First gear test - Able to monitor digitally as well as adjust the PSI on both the UP/DWN side.
- Avionics - All electrical components wired, plugged in and NO SMOKE
- Wings - Painted, .50 cal brownings blended into wing, anodized to give burnt effect.
- Fuel - added connector in rear baggage compartment to allow Ferry option (turtlepack)
- Fairings cut, glassed and molded to fit better than the ones received.
- Cowling custom, wing tips custom, tail - In for spray
- Fuselage right side being closed up (left already closed)
- These users thanked the author Little Friend for the post (total 2):
- Hammer • Chalkie
Whistling Guns
- Too Tousand
Nothing but the best, from RCA.
- Little Friend
- Frequent AvComer
- Has thanked: 206 times
- Been thanked: 100 times
The aircraft is a legend in its own right, but what stands out here most for me is.... the workmanship here is impeccable...
- These users thanked the author Shepherd for the post:
- Little Friend
- Commercial Drone Pilot and aspiring PPL/CPL (H)
- Professional Photographer
- Freelance Film Producer
- Fuelling up
Sneak Pics
- Nose cone painted
- Wings/Flaps/Ailerons/Tips painted
- Rudder painted
- First Engine startup - Roars to life
- These users thanked the author Little Friend for the post:
- Hammer
Whistling Guns
- Fuelling up
Brief run down on ignition! Enjoy
- These users thanked the author Little Friend for the post (total 3):
- Hammer • Chalkie • Ray W
Whistling Guns
