That SOUND, That WHISTLE, Those GUNS...
- Six Tousand
- Closest Airfield: KBDN
- Has thanked: 75 times
- Been thanked: 435 times
Re: That SOUND, That WHISTLE, Those GUNS...
We just fired up an LS3 (with a reversible prop) a few days ago. The hall sensor gave some grief but it sounds great!
They want 40 hours of ground run time before the first flight.
Mike Wissing
Oregon Wing Vice Commander - C.A.P. (USAF Aux)
C.A.P. Search and Rescue Mission Pilot - SAR Mission Check Pilot Examiner.
Professional RV builder company test pilot
I can't wait for computer keyboards to come out with a breathalyzer.
- Tree Tousand
- Closest Airfield: FAOR
- Has thanked: 880 times
- Been thanked: 1404 times
...............................Ugly Duckling wrote: Thu Apr 06, 2023 3:50 pm A small issue that is not understood by many is which way is up (or down) on a gas strut
The piston rod must be at the lowest point as the oil in the cylinder needs to keep the seal lubricated to retain the gas pressure.
I contacted Gabriel when we had gas struts collapsing every 6 months on a mining project. The engineer was very helpful in explaining the reason.
On balance I would say that one is installed the wrong way round as in the normally closed position the Rod is up allowing fluid to drain away from the seal .
- Flying to unmanned aerodrome
- Has thanked: 41 times
- Been thanked: 171 times
Nope, I think you'll find that one is indeed installed correctly. The seal referred to would be the one on the end of the rod (plunger section not the housing section) so when access panel is open as per picture the seal is lying in fluid and when the access panel is closed the whole strut assembly has rotated through almost 180 degrees and the rod has gone the the lower end of the housing where again, it will be lying in fluid.Volo wrote: Sat Apr 22, 2023 8:47 am...............................Ugly Duckling wrote: Thu Apr 06, 2023 3:50 pm A small issue that is not understood by many is which way is up (or down) on a gas strut
- Tree Tousand
........Chris71 wrote: Sat Apr 22, 2023 10:49 amNope, I think you'll find that one is indeed installed correctly. The seal referred to would be the one on the end of the rod (plunger section not the housing section) so when access panel is open as per picture the seal is lying in fluid and when the access panel is closed the whole strut assembly has rotated through almost 180 degrees and the rod has gone the the lower end of the housing where again, it will be lying in fluid.Volo wrote: Sat Apr 22, 2023 8:47 am...............................Ugly Duckling wrote: Thu Apr 06, 2023 3:50 pm A small issue that is not understood by many is which way is up (or down) on a gas strut
Sorry disagree .
As that unit is installed the rod end will be at the top when the door is closed. It should be at the bottom so that the seal is immersed in fluid when the door is closed as it will be closed 99% of its life.
- Tree Tousand
It only rotates just over 90 degrees. From open to closed not 180 degrees
- 10000 and still climbing
- Has thanked: 1949 times
- Been thanked: 2177 times
Paul Sabatier
- Tree Tousand
The seal is fitted on the piston side of the rod i.e the part of the rod furthest from the point where the rod is attached to the airframe. So looking at that picture with the panel in the open position the piston and seal are currently at the bottom end of the gas tube so the seal is lying in the lubricating oil. When the panel is closed the whole strut assembly will rotate and be lying in an almost vertical position. The rod will be at the top and gas tube underneath. But the piston and seal have travelled right into the tube so are sitting at the bottom of the tube, immersed in oil.
It's not the seal on the piston which needs to be kept wet but the cylinder to piston rod which is important
Paul Sabatier
If it is the seal at the bottom of the cylinder and not on the rod that you are referring to then I'm afraid I must eat humble pie and apologize. You are indeed correct Volo. Now who's going to volunteer to tell them it's upside-down?
- Tree Tousand
I bought a Glider trailer 40 years ago and only disposed of it a year ago.
It had two large gas sruts to lift the entire 8 metre roof up
These original struts still function perfectly and as it happens are installed rod end down.
- These users thanked the author Volo for the post:
- Ugly Duckling
- Too Tousand
- Has thanked: 802 times
- Been thanked: 1756 times
SO? Any progress? First flight done? Pilot Report done?Little Friend wrote: Fri Apr 07, 2023 5:58 am Catching a few rays!
Engine ground runs - successful setup and accurately cross checked against ECU/Dynon
- Fuelling up
- Closest Airfield: HKIA
- Has thanked: 16 times
- Been thanked: 54 times
Successful First Flight! Smiles all round…
Flies like an absolute dream!!!
- These users thanked the author Little Friend for the post (total 3):
- Hammer • Chalkie • Roger
Whistling Guns
- Incipient Spin
- Has thanked: 66 times
- Been thanked: 64 times
Brilliant! Looks fantastic!Little Friend wrote: Mon Jun 05, 2023 11:18 am Successful First Flight! Smiles all round…
- These users thanked the author bladerunner for the post:
- Little Friend
- 8000 Tousand
- Closest Airfield: FACT
- Has thanked: 100 times
- Been thanked: 883 times
Fantastic!
Can't wait to see her in the air.
- These users thanked the author Deanw for the post:
- Little Friend
