Seen at FAHL (Hluhluwe Airfield KZN)
Has thanked: 996 times
Been thanked: 4741 times
Hluhluwe Airfield
21 March 2022
Re: Seen at FAHL (Hluhluwe Airfield KZN)
Hluhluwe Airfield
21 March 2022
Hluhluwe Airfield apron area and the two hangars
21 March 2022
The airfield is home to Zululand Air Patrol ( ZAP Wing) which is part of Operation Rhino anti poaching
Since February, my son Keaton (Air Bear) has been the base manager and pilot flying the Bush Cat
http://www.projectrhinokzn.org/zap-wing ... trol-wing/
Rainbow Skyreach Bushcat ZU-FUU
21 March 2022
These users thanked the author Bearcat for the post (total 4):
csparksflyphotonRay WGreg R-S
csparksfly
Has thanked: 646 times
Been thanked: 44 times
Unread post by csparksfly »
Thanks for posting, its nice to see the "youngsters" at it. He looks quite "at home"
The reg should have been ZU-FU2 :twisted:
These users thanked the author csparksfly for the post (total 2):
BearcatRay W
Skill : Luck
What's your ratio?
csparksfly wrote: Tue Mar 22, 2022 2:12 pm Thanks for posting, its nice to see the "youngsters" at it. He looks quite "at home"
He is at Home :) .. He lives in the Park Home that you see behind the aircraft !
csparksfly
21 March 2022
Bukes
Robinson R44 ZS-RMM
19 March 2022
For interest, this morning, Keaton in the Bush Cat with a spotter, were able to identify several poachers who were later apprehended by the ground reaction team... so the system works :) These poachers were not after rhino this time, but were after impala/springbuck for meat. Poachers 0, ZAP Airwing 1 :)
Ugly DucklingMeelperdcsparksflyRay W
Trevor Duane
Closest Airfield: KIZAD
Has thanked: 144 times
Been thanked: 304 times
Unread post by Trevor Duane »
Just a word of caution based on own experience where I have been involved in aerial anti poaching flights in Africa (outside of SA). Sharing of any personal info is a huge security risk to all involved. The operator I was working for at the time went to great lengths to professionally analyze the security threat to the crew and their families. I thought it was over the top till I was briefed on the info properly, then my mind changed big time. Behind the poachers on the ground is a sofisticated network that will pickup on info like this in a heart beat if there operation sees resistance from aerial ops, your info will lead them straight to the source of their problem.
These users thanked the author Trevor Duane for the post:
markus_m2
Trevor Duane wrote: Wed Mar 23, 2022 2:13 am Just a word of caution based on own experience where I have been involved in aerial anti poaching flights in Africa (outside of SA). Sharing of any personal info is a huge security risk to all involved. The operator I was working for at the time went to great lengths to professionally analyze the security threat to the crew and their families. I thought it was over the top till I was briefed on the info properly, then my mind changed big time. Behind the poachers on the ground is a sofisticated network that will pickup on info like this in a heart beat if there operation sees resistance from aerial ops, your info will lead them straight to the source of their problem.
Noted
Christopher
Has thanked: 644 times
Been thanked: 168 times
Unread post by Christopher »
Good job, Keaton!
As far as I recall from my own Zululand days (aeons ago), that first photo is taken looking south, Bruce?
Christopher wrote: Wed Mar 23, 2022 6:13 am Good job, Keaton!
You can see the RWY 21 marking
Robinson R22 ZS-RBM
20 March 2022
Bukes
21 March 2022
BukesCornell Blok
