From the article..
A structural engineer registered with the Engineering Council of South Africa (Ecsa) has to sign off on all installations. According to local structural engineer Marius van Coller, there is a reason for an engineer's inspection.
He says there is a risk of structural collapse if the roof truss design is not adequate for the number of solar panels being installed.
Its my argument that if your roof structure was built to SANS standard as it should be -there is no risk of structural failure as result of adding solar PV panels. If your roof structure was built under spec, then yes, but then even workmen will make your roof collapse if they put load on it. And then it would be an inferior and illegal roof structure from the onset when the house was built. If anything the PV panel rails etc will reinforce the roof, which is tied to the walls and the walls to the foundation of your house.
In terms of
roof top solar geysers this is what
the Installer must be compliant with.
Installers must ensure that the roof structure is able to support the solar system. (SANS 10106:2014 5.3.1)
Where it is not possible to comply, a professional engineer or registered technologist
must design the installation in such a way that the safety and performance principles of the standard are incorporated. (SANS 10254 2017 4.1.1.2 and SANS10106 2014 4.1.7)
• Water heaters or storage tanks with a capacity of 200 litres or more may not be attached to a wall. (SANS 120252-1 2012 8.4.6.5)
I've seen many installations where the 200l tank is fitted to a wall, often in garages or an outside wall.
• The solar system must be installed in such a way that it does not accelerate the deterioration of the roof. (SANS 10400-L, SANS 10243, and SANS 10252-1)
There is no SANS regulation for solar PV panels per se, , except for the wiring code SANS10142-1-2.
But the panels and the fittings are manufactured to international standards, which require them to comply with many regulations globally if they are to be sold in those markets, especially the 1st world markets (EU, AUS etc).
SANS 10142 is for electrical setups and SANS 10106 for
solar water heaters
SANS10142-1-2 only applies to the
wiring code of a solar PV system linked to an inverter. Which needs to be installed by a master electrician (competent person).And for which a CoC is required, and thats completely acceptable - because you dont want
an installer installing inferior wiring to your house for the system.It would also be a requirement of your building insurance that your house wiring is correct and to SANS code, with the system installed.
SANS 10142-1: 2024 Edition 3.2 was released on 12
August 2024. A couple of days ago.
