Bathawk Rating
South African Bat Hawk has been designed and developed by Micro Aviation South Africa primarily for surveillance and is the most affordable light sport aircraft on the market.
KAPT. BOK
Closest Airfield: FAWB- Wonderboom
Has thanked: 13 times
Been thanked: 6 times
Bathawk Rating
Unread post by KAPT. BOK »
Good day
I would please like to know where I can do a Bathawk rating in the Gauteng area? After a few Google searches I have come up short and empty handed.
I would also like to know if there are and Bathawks around for Hire and Fly?
Nic
Welcome to Aviation, you are now broke... \:D/
Has thanked: 984 times
Been thanked: 646 times
Re: Bathawk Rating
Unread post by Fransw »
KAPT. BOK wrote: Tue Feb 14, 2023 12:43 pm Good day
Nic
Not sure if Sue Singleton at Harties still does Bathawk intro flights and ratings. Try Googling her name. Or maybe contact the Pappas(082 828 6706) at Nelspruit. They surely must know where you can get a rating in GP...
http://www.pilotspost.com/arn0000902
"Lucky are they who see beautiful things in humble places where other people see nothing." ~Camille Pissarro
KAPT. BOK
Re: Bathawk Rating
Thank you, much appreciated!
GCronselaar
Post Take off checks
Has thanked: 32 times
Been thanked: 40 times
Re: Bathawk Rating
Unread post by GCronselaar »
I would give Sean Cronin a call at Gluetec (Bathawk fanatic) can also give advice on where to go...
The Aeroplane Flies High, Turns Left, Looks Right
Dish
Finals (unmanned) for a Full Stop
Closest Airfield: Panorama
Has thanked: 3 times
Been thanked: 50 times
Re: Bathawk Rating
Unread post by Dish »
Udo Herpich, may still be instructing on Bantams and Bathawks. ?? around the pretoria area and quite active on Avcom I believe. ??
jean
Airborne from Unmanned field
Has thanked: 163 times
Been thanked: 80 times
Re: Bathawk Rating
Unread post by jean »
Nic
Google is not the only search engine...it gives you what you have already given it. try another. I never use Google.
These users thanked the author jean for the post:
KAPT. BOK
Return to “Bat Hawk”
