Advice on restricted zone
christokruger
Closest Airfield: PLK
Unread post by christokruger »
I'm thinking of getting a Air 3, but noticed on the DJI map that half of my farm, including my house falls in a restricted area(red x). Which restrictions apply in this area?
The airport in question is the Polokwane International airport. which is 15km southwest of my house.
The reason for getting the drone is purely recreational.
Shepherd
Has thanked: 206 times
Been thanked: 100 times
Re: Advice on restricted zone
Unread post by Shepherd »
christokruger wrote: Mon Dec 18, 2023 9:04 am I'm thinking of getting a Air 3, but noticed on the DJI map that half of my farm, including my house falls in a restricted area(red x). Which restrictions apply in this area?
The DJI restricted areas are not aligned to the SACAA areas and aviation laws, so cross compare that first from a legality perspective.
However also from a DJI perspective just NEVER update the restricted area data based after an update and it typically wont prevent you from flying. It will just ask you to acknowledge you are in a "restricted" area and you have limitations in height (typically 500m) and not so much on distance unless you are right next to the airport specifically. Flying recreationally the 500m height limitation wont be an issue for you.
But as always with DJI things do change often with firmwares etc.... I would suggest if you have a friend with a drone to test it out and see it it would work before investing and you are stuck with it.
As always, check this link for the high level breakdown of what you can do with your drone recreationally and be legal. My main point was that the DJI restriction zones are not the same as the SACAA laws and restrictions and you should always follow the SACAA ones over what DJI tells you is possible. (P.S) you wont be sad with a Mini 3 or 4 option of drone either, the 4 being nicer because it has an all in one C2 link device (transmitter) versus one you need to link your phone up to everytime.
SACAA link: https://www.caa.co.za/industry-information/rpas/
- Commercial Drone Pilot and aspiring PPL/CPL (H)
- Professional Photographer
- Freelance Film Producer
christokruger
Shepherd wrote: Mon Dec 18, 2023 11:54 am
Thanks a lot for the detailed response. is there a SACAA map that lists the restricted areas?
IcarusZulu
Closest Airfield: Magalies Gliding Club
Been thanked: 1 time
Unread post by IcarusZulu »
christokruger wrote: Mon Dec 18, 2023 8:30 pm Thanks a lot for the detailed response. is there a SACAA map that lists the restricted areas?
The KMZ airspace file can be found here... https://atns.com/products-services/aim/ ... n-3d/7423/
Engines who needs em anyhow?
ZS-GPD, ZS-GXA
csparksfly
Has thanked: 690 times
Been thanked: 43 times
Unread post by csparksfly »
Also have a look at drones.org.za
Skill : Luck
What's your ratio?
csparksfly
and for "notams": https://www.b4flight.co.za
Skill : Luck
What's your ratio?
Return to “Drones, UAVs”
