🎁 New Feature: @Mentions
Tips and Tricks to get the most out of your AvCom experience.
Roger
Closest Airfield: FAPE
Has thanked: 346 times
Been thanked: 828 times
Unread post by Roger »
We have added a new feature to AvCom called @Mentions.
You can now mention a user by starting to type a @ in the normal posting field.
Once you select a user from the dropdown, the [mention] Code will be inserted. After submitting the post it will create a notification to that user.
You want to be notified if someone mentions you in a post?
This is controlled through the normal notification setup attached to your profile.
You can be notified either via the normal board notification system(the bell at the top of the screen) or by mail, or both.
In the notification setup panel, check the last option - Someone mentioned me
(Whilst you are there, check out that your other notifications are also set as you wish them.)
Click here for your Notification Control
Just our little Christmas present to you. Hope you enjoy it!
These users thanked the author Roger for the post (total 3):
V5 - LEOrudolphscharledz
rudolphschar
Closest Airfield: Worcester
Has thanked: 279 times
Been thanked: 212 times
Re: 🎁 New Feature: @Mentions
Unread post by rudolphschar »
Hopefully we get the dislike button next year for Christmas :D
These users thanked the author rudolphschar for the post (total 2):
AnAV8Rboneman
Rudolph Scharneck
Member of the Cape Gliding Club
Favourite quote: The problem is not the problem, the problem is your attitude about the problem.
Return to “Using the Forum - Tips & Tricks”
