Embraer 145 AME Positions - Solenta Aviation (Pty) Ltd
Positions in the Administrative, Operational, Engineering or any other aviation support field.
Forum rules
estelle.seager
Mags On
Closest Airfield: Lanseria Airport
Unread post by estelle.seager »
Solenta Aviation have positions available for Licensed Aircraft Maintenance Engineers.
The positions are based at O.R. Tambo.
Below please find a description of the role and the requirements.
• Carry out all scheduled maintenance - in accordance with the work pack provided and verify availability of spares.
• Carry out unscheduled maintenance, including fault finding/rectification and compiling spares list as required during
inspection.
• Adhere to all document control procedures and regulations.
• Ensure communication w.r.t. progress, team members and unplanned tasks/situations to Manager.
• Ensure each workstation carries only aircraft specific documentation.
• Responsible for the safety and cleaning of the allocated area.
• Ensuring correct store procedures are followed and documentation completed.
• MOP and process / procedure adherence and familiarization.
• Signing of the Certificate of release to service.
• Brief Pilot before flight after maintenance by your team and accompany the Pilot with his walk-around.
• In addition to the above, you may be required to perform all reasonable duties assigned to you or related to the proper completion of your job tasks.
License Requirements:
W - Avionics
W - Instruments
W - Electrical
License Requirement:
A - Embraer 145
C - RR AE3007A
Remuneration & Benefits
- US Dollar based Salary
Please send your cv to hr@solenta.com should you meet the above requirements.
POPIA Consent
- By submitting your CV, you confirm that;
1. We may retain your personal information in our database for future matching.
2. We may contact you when suitable opportunities arise.
3. The information you have provided to us are true, correct and up to date.
We endeavour to reply to each and every application, however, should you not hear back from us withing 14 days please consider your application unsuccessful.
Return to “Administration, Operations, Engineering and Other Support”
