2 Delta aircraft collide on taxi way at Hartsfield-Jackson Atlanta
Vaughan K
Mags Dead Cut
Closest Airfield: Petit
Has thanked: 41 times
Been thanked: 7 times
Unread post by Vaughan K »
This happened a short while ago
These users thanked the author Vaughan K for the post:
LASS 1190
ddevos
Closest Airfield: FAVV
Has thanked: 12 times
Been thanked: 429 times
Re: 2 Delta aircraft collide on taxi way at Hartsfield-Jackson Atlanta
Unread post by ddevos »
Dirk de Vos
Snitch
Closest Airfield: Unknown
Has thanked: 177 times
Been thanked: 531 times
Unread post by Snitch »
CCTV of the A350 hitting the CRJ
Patrick AL
Has thanked: 1444 times
Been thanked: 439 times
Unread post by Patrick AL »
Ouch!
...must say.... I am very surprised to see the tailplane -particularly of a T-Tail --'snap off' quite so easily and cleanly-?
I would've thought there would be a substantial vertical structural spar through the rudder and into the airframe around the APU?
-maybe it's there, and it just snapped, rather than get deformed/bent?
Wonder what the structural certification testing protocol is for anticipated tailplane lateral loads - in "G's".
These users thanked the author Patrick AL for the post:
dollar
:smt051
JCA
Closest Airfield: Krugersdorp
Has thanked: 174 times
Been thanked: 430 times
Unread post by JCA »
There was another video circulating with the ATC conversations. The pilot acknowledged that he had hit something and asked if someone could tell him what it was. Situational Awareness failure perhaps? I mean the only thing he could of hit would have been the CRJ. Yes? No?
ddevos
JCA wrote: Wed Sep 11, 2024 10:53 am There was another video circulating with the ATC conversations. The pilot acknowledged that he had hit something and asked if someone could tell him what it was. Situational Awareness failure perhaps? I mean the only thing he could of hit would have been the CRJ. Yes? No?
The pilots of both aircraft are to blame in my view. Why was the CRJ stopped too close to the taxiway used by the A350? And, as JCA hinted already, why did the A350 pilots not check for clearance? It's not as if that red and blue tail could possibly blend in with the background!
These users thanked the author ddevos for the post:
JCA
Dirk de Vos
Patrick AL
Patrick AL wrote: Wed Sep 11, 2024 8:31 am Ouch!
Also puzzled why cameras are not installed in large airliners to feed airframe/surroundings live images to cockpit? --it's done in every second car nowadays, so it's not about the tech not being available.
:smt051
MadMacs
Closest Airfield: Milkyway
Has thanked: 1040 times
Been thanked: 352 times
Unread post by MadMacs »
Clearer view
“Aviation is the branch of engineering that is least forgiving of mistakes.”
MadMacs
Patrick AL wrote: Wed Sep 11, 2024 11:57 am
Usually the tail has 6 bolts holding the v stab to a fitting on the fuselage. I'll try and find a photo and post it here.
These users thanked the author MadMacs for the post:
Patrick AL
MadMacs
Typical A380 fitting,
Patrick AL
dollar
Airborne from Unmanned field
Has thanked: 814 times
Been thanked: 244 times
Unread post by dollar »
I believe that there are a number of attachment points rather than any sort of spar running through? In that case the fixed point of resisance is at the fuselage and you gain leverage the higer you push it. Levers - powerful ancient tech ;-)
These users thanked the author dollar for the post:
Patrick AL
MadMacs
Christopher
Has thanked: 956 times
Been thanked: 257 times
Unread post by Christopher »
"...er, we just hit something on the taxiway: can you tell us what it was?"
As if they didn't know or couldn't work it out!! :oops:
