........................................................................John.com wrote: Wed Oct 16, 2024 9:23 amI was on site after the aircraft had been removed, and can confirm ZERO fuel spill.heisan wrote: Tue Oct 15, 2024 8:54 pmWhile air in the fuel tanks is a common cause of engine stoppage, you may be reading too much into the lack of fire.MLyons wrote: Tue Oct 15, 2024 6:17 pm
Was thinking the same.
Either that or some new type of tanks/fuel bladders that can withstand a severe disassembly of an airframe and wings without spilling a drop....![]()
Fire requires 3 elements - fuel, oxygen and ignition. With a dead stop accident like this, there is no ongoing movement to generate additional ignition sources. So by the time the fuel and air mix there is nothing left to ignite it. So it is not uncommon to see such accidents where a significant volume of fuel is spilled, but there is no fire.
Does that mean there was no fuel to spill or the tanks weren't breached .?
