Gyro Hover flight
Has thanked: 2120 times
Been thanked: 2162 times
Re: Gyro Hover flight
TC wrote: Mon Oct 21, 2024 1:33 pm
jtresfon wrote: Mon Oct 21, 2024 10:40 am Really? Surely a fixed wing at zero indicated airspeed is stalled and falling/spinning? How can it be flying? Not being facetious, I'm geniunely curious? Jean.
Spoken like someone who’s never left a pitot cover on :D
The "airspeed live" call out was a good indication of the oversight
Paul Sabatier
20048
Steep Turn Right
Has thanked: 18 times
Been thanked: 19 times
Unread post by 20048 »
Mike Wissing wrote: Mon Oct 21, 2024 5:52 am I can make a C172 and 182 fly at zero indicated airspeed too! Am I actually hovering? 😉😁
Indicated Airspeed? :shock:
Propwash
southside
Closest Airfield: around
Has thanked: 33 times
Been thanked: 891 times
Unread post by southside »
20048 wrote: Mon Oct 21, 2024 7:45 pm
I have done this too in a C182 many years ago. One can ‘hang it on the prop’
Obviously at a safe altitude to demonstrate the performance. Or lack thereof. Whatever you want to call it. Definitely not on the good side of the drag curve. But it can be done.
The C182 is a fantastic aeroplane. When you compare it to the C172, you can put the 182 into a steep turn, one or two up trims and sit on your hands and it will sit like you are, perfectly… while you observe the bomber pilots fighting the fire below you.
These users thanked the author southside for the post:
NunoCarreira
Closest Airfield: Mossel Bay
Has thanked: 1632 times
Been thanked: 2315 times
Unread post by Whirly »
The late Dirk de Vos showed it to me in a C210, on take off. :shock:
These users thanked the author Whirly for the post:
Mike Wissing
Captain Gyro
Has thanked: 81 times
Been thanked: 122 times
Unread post by Captain Gyro »
https://www.dropbox.com/scl/fi/p1mzdofw ... pakbx&dl=0
Here's a video I made of a vertical descent in my gyro. The rotor RPM only slightly drops in the vertical descent, but then maintains its value, and one can remain in this state, as long as one has altitude to lose. Have done this from 10 000ft all the way to SL. Nice quick way of getting down.
These users thanked the author Captain Gyro for the post (total 2):
WhirlyNunoCarreira
Mike Wissing
Closest Airfield: KBDN
Has thanked: 95 times
Been thanked: 513 times
Unread post by Mike Wissing »
If that’s a question, yes indeedy!
It’s a great demo for a student to see if they understand how that is possible!
These users thanked the author Mike Wissing for the post:
Jean Crous
Mike Wissing
Oregon Wing Vice Commander - C.A.P. (USAF Aux)
C.A.P. Search and Rescue Mission Pilot - SAR Mission Check Pilot Examiner.
Professional RV builder company test pilot
I can't wait for computer keyboards to come out with a breathalyzer.
Mike Wissing
Jean.
Jean, to understand why I stated zero INDICATED airspeed is a clue. The air impacting the pitot tube is at such a high angle of attack as to give a false reading on the ASI. The aircraft is not stalled, even though it may be behind the power curve and pretty close to stalling.
This is best attempted with an instructor on board who is not scared of high nose attitudes! 😉
You are welcome to pm me if you’d like a more in-depth response.
These users thanked the author Mike Wissing for the post (total 2):
jtresfonNunoCarreira
Mike Wissing
Mike Wissing
The cure for having left your pitot cover on is to turn on pitot heat……burns through the nylon sleeveand bobs your uncle, live airspeed again.😈😇
Mike Wissing
mikev
Airborne from Unmanned field
Closest Airfield: FAKD
Has thanked: 133 times
Been thanked: 43 times
Unread post by mikev »
TC wrote: ↑Mon Oct 21, 2024 1:33 pm
jtresfon wrote: ↑Mon Oct 21, 2024 10:40 am
I hovered my Savannah MXP740V twice.
Wind was about 32 Km/h+ and I used about 70% power, full flaps.
Both instances were over my own runway, those that had been there will know there are no objects causing wind inconsistencies.
Height was at 1,5M (Low enough for the undercarriage to handle the shock should I sink through) and I actually had it gaining a little when power was (GENTLY!!!) increased and descending when decreased with both hovering parts of the flight lasting about a minute.
Both instances ended when I realized the folly of gaining only bragging rights for the potential fat bill if things went pear shaped!
I must mention that my Savannah was built with the Leading edge slats wing, left completely unpainted with only the oxidization proofing between plates, especially for the max Low-and Slow effect. Power off stall was below 25 mph, how much, I don't know as ASI read Zero due to the AOA.
So, yes! Fixed wings can hover!!
These users thanked the author mikev for the post:
NunoCarreira
“Start by doing what’s necessary; then do what’s possible; and suddenly you’re doing the impossible.”– Francis of Assisi
AJW
Closest Airfield: FAKT
Has thanked: 39 times
Been thanked: 41 times
Unread post by AJW »
During the 90's when I was in Ladysmith and they still had proper airshows, I can recall on more than one occasion where the crop sprayer flew backwards during his display.
Cornell should remember this as well, not sure how old he was back then.
Be safe
Abrie
Volo
Has thanked: 938 times
Been thanked: 1531 times
Unread post by Volo »
I remember an aircraft tracking backwards across the field @ Virginia airfield ( Durban ) @ an airshow in the 50s
The term flying Jeep has stuck in my mind - I have an idea it was that aircraft that Frank Perssons father owned ?
MaverickKevin
Post Take off checks
Has thanked: 41 times
Been thanked: 39 times
Unread post by MaverickKevin »
Aircraft tracking backwards or demonstrating zero groundspeed, I don't feel are "hovering", as a fixed wing aircraft cannot do that in zero wind conditions.
These users thanked the author MaverickKevin for the post (total 2):
AJWapollo11
Remember- the mags are always hot, the oil cap is always loose ...
Aviate Navigate Communicate!
