Fuel starvation (Baron near Senekal)
- Closest Airfield: Kroonstad
- Has thanked: 8 times
- Been thanked: 115 times
Apparently left Bethlehem for Bloemfontein and ran out of fuel at Senekal and botched the landing on the grass strip next to the N5
Happened on October 10
- These users thanked the author Rotor Mad for the post:
- NunoCarreira
Political correctness is a doctrine, fostered by a delusional, illogical minority and promoted by the mainstream media which holds forth the proposition that it is entirely possible to pick up a piece of $h!t by the clean end.
- Taxiing
- Closest Airfield: FALE
- Has thanked: 77 times
- Been thanked: 11 times
Re: Fuel starvation
Very sad to see this. My Dad owned this Baron in the 1990's. I did my initilal Comm/IFR test in her!
- These users thanked the author SHREKKIE for the post:
- dollar
The OLDER we get, the FASTER we were!
- 10000 and still climbing
- Closest Airfield: Mossel Bay
- Has thanked: 1635 times
- Been thanked: 2314 times
Re: Fuel starvation
Senekal is still a long way from Bloemfontein.
- These users thanked the author Whirly for the post (total 2):
- ejacobszuk • Rooijan
- Frequent AvComer
- Has thanked: 100 times
- Been thanked: 54 times
Re: Fuel starvation
Rushed pre-flight?
- These users thanked the author CWS for the post (total 2):
- Air Speed • Rotor kop
- Tree Tousand
- Closest Airfield: FAVV
- Has thanked: 12 times
- Been thanked: 429 times
Re: Fuel starvation
And with so little fuel left, the previous flight might have been a bit risky as well...CWS wrote: Thu Oct 24, 2024 8:13 pm IMG_0703.jpeg
Bethlehem is really close to Senekal? Tanks must have been pretty much dry on takeoff???
Rushed pre-flight?
Dirk de Vos
- Mags Dead Cut
- Closest Airfield: FASY
- Has thanked: 38 times
- Been thanked: 62 times
Re: Fuel starvation
Fuel might have been stolen and they didnt notice ? Thats happened to me more than once but I picked it up on the gages and dip. You fill up the night before and so confidently take off with air in the tanks because fuel has been liberated during the night by persons unknown ?CWS wrote: Thu Oct 24, 2024 8:13 pm IMG_0703.jpeg
Rushed pre-flight?
- Wanna Fly
- Closest Airfield: FATP
- Has thanked: 1 time
- Been thanked: 3 times
Re: Fuel starvation (Baron near Senekal)
Was on 10 October, not 11. Wasn't a botched landing on a grass strip. Wheels would not come out on battery power on downwind leg. Circuit breaker popped. Landed on N5 and skidded off as there was no directional control. Very responsible person assured pilot repeatedly before flight that the tanks were filled up. The preflight was rushed, no excuse there.
- These users thanked the author eurosurfer for the post (total 3):
- Rotor kop • Mouser • Whizzwheel
Groete / Regards
SPS
SPS
Not looking at the fuel gauges after take off ? That is part of the FREDA checks after take offeurosurfer wrote: Fri Oct 25, 2024 10:08 am Was on 10 October, not 11. Wasn't a botched landing on a grass strip. Wheels would not come out on battery power on downwind leg. Circuit breaker popped. Landed on N5 and skidded off as there was no directional control. Very responsible person assured pilot repeatedly before flight that the tanks were filled up. The preflight was rushed, no excuse there.
- Rotor kop
- Fife Thousand feet
- Closest Airfield: FAHV
- Has thanked: 153 times
- Been thanked: 808 times
Phew!!! Taking off without looking into the fuel tanks = this…
Bethlehem to Senekal is only 37 nm. At Baron speeds, this would take around 12 minutes, meaning there could not have been anything more than 30 litres on board at start-up.
A fitting came loose on my Comanche, a few months ago, in flight, and I lost 35 liters from one auxiliary tank, without noticing it.
This once again emphasised how critical it is to peek into the tanks before takeoff. Had I not, we would have run out of fuel on our return flight from the Kalahari.
- These users thanked the author Lood for the post (total 2):
- Rotor kop • AEH
- Straight and Level
- Closest Airfield: FAGM
- Has thanked: 420 times
- Been thanked: 111 times
There's only 1 responsible person you can trust - yourself... And in this case he wasn't responsibleeurosurfer wrote: Fri Oct 25, 2024 10:08 am Very responsible person assured pilot repeatedly before flight that the tanks were filled up. The preflight was rushed, no excuse there.
- These users thanked the author Still_Learning for the post:
- jimdavis
- Heli Pilot agrees to buy Super.
- Closest Airfield: FASD
- Has thanked: 159 times
- Been thanked: 250 times
Does the Baron have the same issue as the Seneca II/III? The filler cap of the Seneca is towards the wingtip and because of the dihedral you can still have a lot of fuel even with a dipstick reading zero. According to one report[1] you can't get an accurate fuel level when dipping tanks with less than 75% fuel remaining.
So you have to trust the fuel gauges, even though their reliability is questionable.
I believe the standard solution is to fill the tanks as often as possible. But if you are away from home without options for fuel and someone drains your tanks then it might be hard to detect.
[1] https://assets.publishing.service.gov.u ... 026656.pdf
Matthew French
ZU-DRO : Cubby Mk II
Has the supply of Avgas resumed at Bethlehem yet?
- These users thanked the author Whirly for the post:
- Richard Smit
- Tree Tousand
Yes, see viewtopic.php?t=268210 ...
Dirk de Vos
" we are in the process of getting it going again", makes me think "not yet". From a private supplyer, yes, if you know about him though.
- Been thanked: 126 times
Hi Aviators,
The pilot explained in detail, so lets dont nock him it can happen to anybody once.
- These users thanked the author flypiper for the post (total 4):
- eurosurfer • Mustang • skydancer • fred.swanepoel@icloud.com
Flying!!!
