Fuel starvation (Baron near Senekal)
Funflier
Reaching altitude
Closest Airfield: FASD
Has thanked: 2 times
Been thanked: 63 times
Re: Fuel starvation (Baron near Senekal)
Unread post by Funflier »
That is some serious damage. Glad the pilot is ok.
These users thanked the author Funflier for the post:
Mouser
Closest Airfield: Mossel Bay
Has thanked: 1635 times
Been thanked: 2314 times
Unread post by Whirly »
flypiper wrote: Sat Oct 26, 2024 6:31 am Hi Aviators,
The pilot explained in detail, so lets dont nock him it can happen to anybody once.
So I take it, eurosurfer was the pilot? Glad he is OK.
These users thanked the author Whirly for the post:
ZU-AYR
Mike Wissing
Closest Airfield: KBDN
Has thanked: 97 times
Been thanked: 514 times
Unread post by Mike Wissing »
Did I miss that post?
Mike Wissing
Oregon Wing Vice Commander - C.A.P. (USAF Aux)
C.A.P. Search and Rescue Mission Pilot - SAR Mission Check Pilot Examiner.
Professional RV builder company test pilot
I can't wait for computer keyboards to come out with a breathalyzer.
Closest Airfield: George FAGG
Location: Hoekwil, near Wilderness, near George, Western Cape
Has thanked: 2808 times
Been thanked: 4456 times
Unread post by jimdavis »
Hell, Flyp, nothing happened to the pilot - he crashed the aeroplane by being in a hurry and taking a fat chance.
Apply Chalkie's second rule - hurry up slowly.
These users thanked the author jimdavis for the post (total 2):
RooijanAEH
www.jimdavis.co.za for flying text books, and true flying stories.
87Juliet
Has thanked: 360 times
Been thanked: 326 times
Unread post by 87Juliet »
jimdavis wrote: Tue Oct 29, 2024 8:49 am
No Uncle Jim, he crashed the airplane because he ran out of fuel and didn't have his finger pulled out...
Jacques Taljard: Zero-Ate-Two Niner-4-Wun Seven-Zero-Sex-Too
Mike Wissing
87Juliet wrote: Tue Oct 29, 2024 9:36 am
Why did he run out of fuel?
Mike Wissing
Grog
Engine Still Cranking
Has thanked: 17 times
Been thanked: 21 times
Unread post by Grog »
Mike Wissing wrote: Tue Oct 29, 2024 7:39 pm
Post #7- someone else assured him that the talks were full
Christopher
Has thanked: 963 times
Been thanked: 257 times
Unread post by Christopher »
<someone else assured him that the talks were full> even though the gauges disagreed! :shock:
These users thanked the author Christopher for the post:
Peter Allen
fly1981
Changing Underwear
Closest Airfield: All over
Has thanked: 4 times
Been thanked: 33 times
Unread post by fly1981 »
Vogoff wrote: Fri Oct 25, 2024 2:04 pm Does the Baron have the same issue as the Seneca II/III? The filler cap of the Seneca is towards the wingtip and because of the dihedral you can still have a lot of fuel even with a dipstick reading zero. According to one report[1] you can't get an accurate fuel level when dipping tanks with less than 75% fuel remaining.
So you have to trust the fuel gauges, even though their reliability is questionable.
I believe the standard solution is to fill the tanks as often as possible. But if you are away from home without options for fuel and someone drains your tanks then it might be hard to detect.
[1] https://assets.publishing.service.gov.u ... 026656.pdf
First of all, it is not possible to use a dipstick to check the fuel level on the baron, nor any other twin I have flown( accurately) . The baron has two fuel gauges, one on each inboard wing, and one in the cockpit for each wing tank. If the pilot assumed it was filled up, you could open the filler cap, and you would see fuel, would probably take around 5 seconds. Situations like this, if it was indeed fuel starvation, are completely inexcusable.
These users thanked the author fly1981 for the post:
RostonD1
Vogoff
Has thanked: 159 times
Been thanked: 250 times
Unread post by Vogoff »
fly1981 wrote: Sat Nov 02, 2024 6:27 pm First of all, it is not possible to use a dipstick to check the fuel level on the baron, nor any other twin I have flown( accurately) . The baron has two fuel gauges, one on each inboard wing, and one in the cockpit for each wing tank. If the pilot assumed it was filled up, you could open the filler cap, and you would see fuel, would probably take around 5 seconds.
But what happens in a situation where one has to fly to a remote field and you can't fill up? You calculate you have two hours of fuel remaining but if someone steals half of your fuel overnight then how can you verify what the fuel gauges are saying?
I guess the moral of the story is you sometimes have to trust your fuel gauges. Or rather: trust, but verify by regularly recalibrating. Easy enough to do by looking at the gauges before filling up and estimating how much fuel will be required. After filling up subtract the amount of fuel added and then you have an idea of how much the gauges match your reality.
Matthew French
ZU-DRO : Cubby Mk II
Lood
Closest Airfield: FAHV
Has thanked: 153 times
Been thanked: 808 times
Unread post by Lood »
IIRC, my V35B Bonanza was the same. Once a certain amount of fuel has been burned, you cannot dip to measure the fuel quantity anymore, as there would be no fuel visible, looking through the filler neck. I do seem to remember that shining a flashlight into the tank, from outside and at an angle, it was possible to see if there was fuel in the tanks, but there was no way to know how much.
That said, my V-tail was the only aircraft I owned over 20 years that had properly working and very accurate OEM fuel gauges.
Also standing to be corrected, but I'm sure that all of my Twin Comanche's tanks could be dipped until they were almost empty, just like the single Comanche.
