So unnecessary, more than one video shows lights flashing on the tower.......
Heli Crash Radio Tower
- Aircraft in Hangar
- Closest Airfield: Lanseria
- Has thanked: 18 times
- Been thanked: 9 times
Re: Heli Crash Radio Tower
From a YT channel, think it was a prelim report, at that height the lower light probably blended in with city lights and pilot was possibly looking down at her iPad during communication with ATC (when the accident happened)
- These users thanked the author Thomaz for the post (total 2):
- Rotor kop • Patrick AL
- 8000 Tousand
- Closest Airfield: OR Thambo
- Has thanked: 2892 times
- Been thanked: 472 times
I have seen many towers with lights not working.
- Tree Tousand
- Closest Airfield: FAOR
- Has thanked: 938 times
- Been thanked: 1533 times
If you are going to be flying around at night how would you not know where these towers are .
Had they had a system installed called " Power Flarm " the offending tower would have been in its data base .
It would have appeared on the " Flarm screen " up to 2 miles before the encounter and would have given them a course correction to avoid it.
- These users thanked the author Volo for the post:
- svenolivier
- Has thanked: 57 times
- Been thanked: 155 times
The reason she was looking at her iPad was to see the ADSB position of conflicting traffic ATC had warned her about !. The Flarm obstacle database is an example of a good idea namely that obstacles & cables should be in a national database that can be synced with one click, but importantly the correct place to keep the warning system is, as in flarm - with the software that does the TCAS alerts.Volo wrote: Sun Nov 03, 2024 8:19 am If you are going to be flying around at night how would you not know where these towers are .
info junkie
- Frequent AvComer
- Closest Airfield: FACT
- Has thanked: 1444 times
- Been thanked: 439 times
RIP to the pilot and victims.
On towers/obstacles..
-surely with today's advanced tech in lighting, including LV LEDs, fibre optics, lens tech and miniaturisation, etc., the required minimum lighting should be reviewed and updated by the aviation authorities?
One could probably quite feasibly light up these obstacles up like veritable blinking Christmas Trees - and using mirror and lens tech to give focused and directional lighting to avoid light pollution etc..
- Hee Hee I'm Flying
- Has thanked: 129 times
- Been thanked: 165 times
What about doing your homework on minimum safe altitude before the flight and sticking to it. Below 600'at night with pax is, well, the result speaks for itself. Predictable and avoidable.
- These users thanked the author Arch for the post:
- Kous
- Tree Tousand
How come ATC were unable to advise on their fatal track to the tower . The tower would be on the ATC s screen ?
- Take off Clearance
- Closest Airfield: FAWB
- Has thanked: 102 times
- Been thanked: 54 times
Would it?Volo wrote: Sun Nov 03, 2024 2:10 pm How come ATC were unable to advise on their fatal track to the tower . The tower would be on the ATC s screen ?
I don't know much about the US systems, but surely a TRACON controller would only have/need the MVAs for each sector?
I'm more familiar with the UK's systems, which show the outlines from the SMA chart (eg https://www.aurora.nats.co.uk/htmlAIP/ ... 373955.pdf). They'll then have the Control Zone/Area chart (which has has obstacles etc) above the radar console. (source: YT videos of the EGCC and EGGP radar rooms).
Maybe the systems have these obstacles built in, but I don't think it's a "given".
