Pilatus PC12 NG Captain
Pilot Jobs relating specifically to fixed wing aircraft
Forum rules
Bevs
Closest Airfield: ORT
Unread post by Bevs »
ROLE SUMMARY AND REQUIREMENTS:
Permanent position:
Act as pilot-in-command and second-in-command on PC12 NG aircraft as required by the company. Provide training and checking on PC12 NG
aircraft for the company.
Requirements:
- Valid SACAA CPL (A) or higher license.
- Valid SACAA Instrument Rating (A).
- Valid SACAA Grade II fixed-wing Instructor’s Rating.
- Type rating as pilot-instructor will be an advantage, but not required.
Required fixed-wing experience:
- Minimum 1500 hrs TT, 100 hrs night time, 100 hrs instrument time.
- Minimum 100 hrs command time any fixed-wing turbine type.
- Regional operating experience outside of South Africa.
- Willing and able to be deployed for extended periods away from home on flight operations or standby, subject to limits imposed by applicable
law and by Fireblade Aviation policies for travel, S&T and leave/off-time.
Should you meet the requirements please email your cv to: workforus@firebladeaviation.com
Return to “Aeroplane”
