Item Name:Durafly™ HyperBipe 900mm EPO w/Motor (ARF) - Price reduced
Description:
Believe the hype, the Durafly® ™ HyperBipe is here! Everybody loves a biplane and with its vivid paint scheme, powerful brushless power system and lightweight but durable EPO construction this model is a fantastic sports model that is an extremely capable pattern flyer.
With its colorful scheme, smooth outline and blade-like fuselage it is definitely a looker, but when it comes to aerodynamics & design it ticks all the right boxes. With a slim wing profile and hollow fuselage construction, flight performance of the HyperBipe is extremely precise. Perfect for F3A flying, this model allows you to perform the most delicate of pattern sequences and manoeuvres. It goes exactly where you want it, like it’s on rails! EPO foam technology has come a long way and the HyperBipe greatly benefits from this. It flies like a much bigger balsa model!
Being “Plug and Fly”, the HyperBipe comes with a potent brushless power system (unlimited vertical is a breeze) and servos pre-installed. All you need to do is install your radio equipment, glue in the wings, hook up the linkages and you are ready to go flying!
If you’re looking for a sports model that really stands out from the crowd, the Durafly® ™ HyperBipe is definitely for you. A word of warning, flying the Durafly HyperBipe is addictive!
Features:
• Fast and easy assembly
• Beautiful EPO construction with a vibrant paint scheme
• Pre-installed 3S powertrain offering ample power while keeping weight down
• Fully hinged surfaces
Specs:
Wingspan: 900mm
Length: 900mm
Flying Weight: 610~640g including battery
Motor: 2212 1400kv brushless outrunner
ESC: 30A w/BEC
Servos: 4 x 9g micro servos
Prop Size: 9 x 5
Requires:
Your own 4CH transmitter/receiver
800~1300mAh 3S lipoly battery
https://www.youtube.com/watch?v=PGUXDauj6UM
https://www.youtube.com/watch?v=2dpi_vNXhsU
Condition: Good
Reason for sale:Thinning out the hanger.
Shipping:No
Price:R1350.00 (Not neg)
Payment methods: Cash
Contact: WhatsApp 0Six14515104
Pictures:
[Sold] Durafly™ HyperBipe 900mm EPO
Forum rules
Strictly no commercial adverts. For guidance on our views as to what construes commercial in nature, please click here. If the item is not your personal asset, you must post the contact details of the owner. You are also to ensure you have permission of that person to post their details. Where a template is supplied, all fields are mandatory. Non compliant posts will be deleted with no notice.
- Engine Started
- Closest Airfield: White Hills
- Been thanked: 0
- Engine Started
- Been thanked: 0
Re: [For Sale] Durafly™ HyperBipe 900mm EPO - Price reduced
Civiltwilight wrote: Fri Nov 29, 2024 11:09 am Item Name:Durafly™ HyperBipe 900mm EPO w/Motor (ARF) - Price reduced
Description:
Features:
Specs:
Wingspan: 900mm
Length: 900mm
ESC: 30A w/BEC
Prop Size: 9 x 5
Requires:
Condition: Good
Shipping:No
Pictures:
