[Sold] E-Flite Hawker Hurricane 25e 1360mm - Price reduced
Your models for sale or wanted. Posts with no movement after 120 days are deleted.
No commercial adverts please. If you wish to advertise in the commercial models section as above email: ads@avcom.co.za
Forum rules
Strictly no commercial adverts. For guidance on our views as to what construes commercial in nature, please click here. If the item is not your personal asset, you must post the contact details of the owner. You are also to ensure you have permission of that person to post their details. Where a template is supplied, all fields are mandatory. Non compliant posts will be deleted with no notice.
Civiltwilight
Engine Started
Closest Airfield: White Hills
Unread post by Civiltwilight »
Item Name:E-flite Hawker Hurricane 25e
Description:
This is the E-flite Hawker Hurricane 25e Bind-N-Fly electric airplane. No fighter deserves more credit for saving Britain in its darkest hour than the Hawker Hurricane. Its simple construction allowed it to be manufactured in large numbers and it could be quickly repaired in the field using basic tools. And, despite being slower than the vaunted Spitfire, the Hurricane could out turn many of the enemy fighters it faced and bring its eight Browning machine guns to bear with devastating effect. This surprising maneuverability combined with its sheer numbers are two big reasons the humble Hurricane shot more enemy aircraft down in the Battle of Britain than any other Allied fighter.
Now you can experience the thrill of flying the Hurricane with this remarkably scale park flyer from E-flite. Constructed of tough Z-Foam™ material, the Hurricane 25e BNF comes out of the box with a high-output brushless power system, digital servos and functional flaps. Even the authentic RAF No. 1 Squadron paint scheme has been applied. All that’s left to complete is a few minutes of final assembly while charging the battery.
Features:
Strong, lightweight Z-Foam™ construction
High-output 25-size 1000Kv brushless motor installed
E-flite 60A Pro brushless ESC installed
Digital high-speed metal gear servos installed
Flaps installed
Retracts installed
Realistic RAF No. 1 Squadron paint scheme
The all-scale outline features simulated engine exhaust, air-foiled tail section, scale pilot and clear navigation light lenses to add to the realism of this model
Requires a full-range DSM aircraft system (sold separately)
Specifications:
Wingspan: 52.0 in (1320mm)
Overall Length: 42.0 in (1075mm)
Wing Area: 420 sq in (27.1 sq dm)
Flying Weight: 4.50 - 4.65 lb (2.00 - 2.10kg)
Motor Size: 25-size 1000Kv brushless outrunner (installed)
Radio: 4+ channel full range radio system
Servos: 6 metal-gear digital micro servos (installed)
Speed Control : 60A Pro Switch-Mode BEC (installed)
Recommended Battery: 2200mah 4S
Flaps: Yes
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Needed To Complete:
A 4+ full-range aircraft transmitter. 5+ channels are required for flap operation, and 6+ channels are required for flap and retract operation.
https://www.youtube.com/watch?v=BTFhKCyJM74
https://www.rcgroups.com/forums/showthr ... ricane-25e
Condition: Good
Reason for sale: Thinning out my hanger.
Shipping: no
Price: R1650.00 (not neg.)
Payment methods: Cash.
Contact: WhatsApp; 0six14515104
Pictures:
Last edited by Civiltwilight on Sun Dec 15, 2024 10:23 am, edited 1 time in total.
Civiltwilight
Engine Started
Re: [For Sale] E-Flite Hawker Hurricane 25e 1360mm - Price reduced
Bump
Return to “Model Personal Classifieds”
