At ATPL level the ATPL student might bump into the odd exam question that requires the application of the Trigonometric Sine Rule and Cosine Rule for the solution. In Navigation it is often used in conjunction with the Polar Stereographic Chart (often when there are two different latitudes mentioned in the question) – in Radios for RNAV calculations.
It is not particular difficult, but as with anything else in life, currency is everything. Typically you will have to use both Sine- and Cosine Rule – the one leading to the other.
Prior knowledge required:
Solid knowledge of Polar Stereographic theory:
• Also how to sketch the chart – North Polar chart means all longitudes are drawn North inwards, towards the centre. All direction is still measured clockwise from North. Greenwich is at the bottom and the International Date Line is drawn at the top of the sketch.
• South Polar chart means all longitudes are drawn from the centre with North outwards. The Greenwich line is drawn at the top and the International Date Line at the bottom of the sketch.
• All latitudes are concentric circles
• Latitudes are still 60nm apart.
Basic Trigonometry - the sine rule is used when we are given either a) two angles and one side, or b) two sides and a non-included angle.
The cosine rule is used when we are given either a) three sides or b) two sides and the included angle.
Geometry - opposing angles between two straight lines are equal in size
Basic mathematics skills – BODMAS, inverse operation, etc.
Good understanding of your scientific calculator.
Example Question follows below...
ATPL Navigation Exam - Sine Rule/Cosine Rule Application
- Too Tousand
- Closest Airfield: St Francis Field
- Has thanked: 45 times
- Been thanked: 373 times
- These users thanked the author Brand Wessels for the post (total 5):
- Chopper One • jimdavis • IKTAV • Hexapilot • vlammie
Brand Wessels
073 337 9154
Brand Wessels
073 337 9154
- 10000 and still climbing
- Closest Airfield: George FAGG
- Location: Hoekwil, near Wilderness, near George, Western Cape
- Has thanked: 2783 times
- Been thanked: 4364 times
Re: ATPL Navigation Exam - Sine Rule/Cosine Rule Application
Good stuff Brand. Haven't used Sin Cos and Tan for a hell of a long time - In fact we used to look their values up in tables. What happens now - does your calculator give you the values?
www.jimdavis.co.za for flying text books, and true flying stories.
- Too Tousand
Morning Jim - indeed it does. Same with logs. As a result there are many more questions to be done in the same exam time. The whizzwheel and CX2/3 nav computers mostly take care of the sin- and cos rules - while solving the triangle of velocities. In 2004 my first ATPL student ever (he was 59 then and from the celestial navigation era) was still able to apply all the trigonometry and manual multiplication and division without using a scientific calculator. I was very impressed - but I had to convert him to the electronics, simply because of the speed required in the exams. Interestingly enough - my youngest (now at university) still have a substantial component of manual skills requirements (no calculator allowed). They feel it is important for the student to still understand the thinking process - correctly so.jimdavis wrote: Mon Dec 16, 2024 5:12 pm Good stuff Brand. Haven't used Sin Cos and Tan for a hell of a long time - In fact we used to look their values up in tables. What happens now - does your calculator give you the values?
- These users thanked the author Brand Wessels for the post:
- Insane
Brand Wessels
073 337 9154
Brand Wessels
073 337 9154
- Too Tousand
Bump.
Brand Wessels
073 337 9154
Brand Wessels
073 337 9154
- Too Tousand
Brand Wessels
073 337 9154
Brand Wessels
073 337 9154
