Aquila wrote: Sun Jan 19, 2025 5:02 pm
How is this different from other aircraft made by Boeing such as the B777?
Every prior Boeing model had manual reversion, with actual mechanical control of elevators and ailerons. No hydraulics or electrics required to operate them.
From the 777 onwards, system design is similar to airbus.
The A350 can lose both of its hydraulic systems and land safely with the use of its EBHA's and EHA's
But it those still require electrical power - hence 2 additional levels of backup power supply on Airbus aircraft.
Are you saying that other manufacturers have less competent engineers?
No. I am saying some armchair commentators on this thread are likely not competent engineers. Airbus engineers given the same fundamental system design and regulatory requirements of the 737-800 would almost certainly have produced the same CVR and FDR design as Boeing engineers did.
I also read that some posts indicate that later models of the aircraft does have a backup power source to the recorders. Why was this change made if you reckon it was unnecessary?
It became necessary because the regulatory requirements changed. Boeing did not modify the system design - instead got Honeywell to produce a CVR with built in battery backup instead.
This upgraded CVR was made available as a retrofit on older models, but I don't think any airline opted to install one (extra cost, weight and a life limited battery to go on the maintenance schedule, etc.). As noted before, these offer no benefit to the airlines themselves, so it is a grudge sale. They will not install them unless the regulators demand it.
