Aviation WX missing
- Has thanked: 814 times
- Been thanked: 244 times
Re: Aviation WX missing
Of all the systems I would like to be asked to recover this would probably be the easiest. Why? Because it's a weather information system. The data ages out fast - like by tomorrow. So if I had accesss to a clean server - as I have previously, described the system would be back up and running within hours. I would simply leave all the old weather behind and start with the new stuff
Realtime process control systems are also fairly quick to recover - as long as you have the parameters. Not so accounting, CRM, pensions etc. It's not rocket science to harden a server against hackers. Basics. It does'nt cost more money. It's built into the operating system and should be built into the network environment. One caveat to this - they may have been running this on WinXP, then they are in doo doo. But it's been made perfectly clear for years that these machines should not be connected to the Internet. But they would never have been that dumb.
- 10000 and still climbing
- Closest Airfield: FAGC
- Has thanked: 142 times
- Been thanked: 1736 times
- Tree Tousand
- Closest Airfield: FAWB
- Has thanked: 176 times
- Been thanked: 416 times
Just tried it - still no joy
The sky is not the limit....
ZS-MDK
Karl Eschberger
ZS-MDK
Karl Eschberger
- Closest Airfield: FAOR
- Has thanked: 1533 times
- Been thanked: 560 times
Working for me and it is super fast. FAIR radar image is 2 days behind, but other locations are working.
But a lot of functionality is still missing.
Online photography portfolio at https://helihub.org from around South Africa with contributions from friends and colleagues.
- Tree Tousand
- Closest Airfield: FAHT
- Has thanked: 26 times
- Been thanked: 67 times
Did you try: https://aviation.weathersa.co.za/
Pleased that we cansee Aerosport/Spot Graphs again.
METARS from most stations still not being reported.
- Tree Tousand
It's still somewhat under construction, but will get there soon enough.
FAIR is up to date now.
- These users thanked the author cage for the post:
- Bell 407
- Tree Tousand
- Closest Airfield: FAVV
- Has thanked: 12 times
- Been thanked: 429 times
The original main site (http://www.weathersa.co.za/) is still very much down, so any other site or system depending on data from it will be struggling. It does seem that they are finally switching to a "secure site", https://www.weathersa.co.za/, but there is simply nothing to see yet. On the aviation weather site they haven't changed the address to the main site yet...
Dirk de Vos
- Closest Airfield: VHHH or FACT
- Has thanked: 35 times
- Been thanked: 56 times
Had a quick look on the site and seems to be up and running again. Also checked Jeppesen FD Pro, its now again receiving METARS and TAFs for SA airports...
- These users thanked the author Aquila for the post:
- csparksfly
Raccoon jet driver...
See Horizons!
See Horizons!
Kindly note that our network is down affecting access to the aviation website. We will be sending this compilation in the interim while the issue is being addressed by our ICT
