Reims Rockets in SA
JCA
Closest Airfield: Krugersdorp
Has thanked: 165 times
Been thanked: 423 times
Reims Rockets in SA
Unread post by JCA »
Good evening everyone,
Does anyone know of any Reims Rockets in SA and where they might be based? Bearcat perhaps?
Snitch
Closest Airfield: Unknown
Has thanked: 176 times
Been thanked: 534 times
Re: Reims Rockets in SA
Unread post by Snitch »
Google brings up a few on quick search
ZS-IWR
ZS-KEZ
ZS-OCM
ZS-OXS
ZS-OYY
ZS-OFT
ZS-PXK
ZU-IGG
These users thanked the author Snitch for the post:
JCA
ddevos
Closest Airfield: FAVV
Has thanked: 12 times
Been thanked: 414 times
Unread post by ddevos »
Here are some more that we've had in air races:
ZS-IXW
ZS-JTA
ZS-KBD
ZS-LHM (now used on a Cessna 500 Citation)
ZS-PEH
ZS-OFT has been exported to Somalia.
Dirk de Vos
Closest Airfield: Mossel Bay
Has thanked: 1516 times
Been thanked: 2111 times
Unread post by Whirly »
I flew an A2 registered one here in SA, I think it became ZS again later.
markw
Closest Airfield: Emoyeni
Been thanked: 13 times
Unread post by markw »
ZS-IWR
Cheetah XLS
Cessna Reims. Rocket
Evektor Harmony
Jabiru
Piper
Sai Marchetti
Foxbat
ddevos
markw wrote: Wed Feb 05, 2025 6:08 pmZS-IWR
It's been repainted some years ago, similar design but different colours, also minus the tail skid...
Dirk de Vos
Hexapilot
Taxiing to Clubhouse
Closest Airfield: Waterkloof
Has thanked: 26 times
Been thanked: 96 times
Unread post by Hexapilot »
ddevos wrote: Thu Feb 06, 2025 1:09 am
That "Tail skid" looks more like a Tost hook...
Going fast
Going up
Say my name...
DISCLAIMER:
DO NOT TAKE ME SERIOUSLY!!!
ddevos
Hexapilot wrote: Fri Feb 07, 2025 9:07 am That "Tail skid" looks more like a Tost hook...
Yep, I guess I should have used quotes for it as well...
Dirk de Vos
JCA
The Reims built 'Cessnas' could be fitted with Tost hooks as they weren't subject to US STC's. Real Cessna's can only be fitted with Schweitzer tow hooks as per the attached photo. There is an STC for this but not for Tost hooks. First fitted to C182's for the World Gliding Comps at Marfa in Texas in 1968.
The hook simply attaches to the tail tie down point with a release cable and lever installed in the cockpit in front of and between the front seats.
These users thanked the author JCA for the post (total 2):
Bearcatddevos
Aviator_nic
Has thanked: 9 times
Unread post by Aviator_nic »
Correct me if I'm wrong but I believe ZS-TKL started its life as a Reims rocket before being converted into a diesel C172 with Project Sky at Wonderboom
ddevos
Aviator_nic wrote: Sat Feb 08, 2025 7:50 pm Correct me if I'm wrong but I believe ZS-TKL started its life as a Reims rocket before being converted into a diesel C172 with Project Sky at Wonderboom
Being a F172P, you are indeed correct. It just so happens to be the same model used by teenager Mathias Rust to land on the Red Square in Moscow back in 1987...
These users thanked the author ddevos for the post:
Aviator_nic
Dirk de Vos
Has thanked: 1130 times
Been thanked: 5350 times
Reims Cessna F172 Diesel Skyhawk is based at Rand and used for training / hour building
This pic from June 2022
JCA
Bearcat wrote: Sat Feb 08, 2025 9:39 pm Reims Cessna F172 Diesel Skyhawk is based at Rand and used for training / hour building
You can only fly it if you buy a watch.............. :shock:
RHUBARB
Man found at unmanned airfield-What now?
Has thanked: 29 times
Been thanked: 6 times
Unread post by RHUBARB »
ZS-OCM was exported to Zambia and is in some anti poaching outfit now
Pete
Has thanked: 290 times
Been thanked: 168 times
Unread post by Pete »
I owned ZS-IYH a 1973 Reims, fantastic aeroplane, lighter on juice than a standard 172 at the same speed.
Full 4 seater and that Conti is as smooth as silk especially with the 3 blade prop STC :D
It was sold up in Africa in the early nineties.
