Replacing steam on a certified aircraft
mi'cmaq
Reaching altitude
Has thanked: 4 times
Been thanked: 82 times
Unread post by mi'cmaq »
Enquiring for a friend whose vacuum pump has packed up on his certified two place aircraft
He would like to chuck out the old steam gauges along with the vacuum pump, regulator and hoses and replace them with a modern EFIS from MGL or Dynon ; also his JPI engine monitor has started dropping some digits and a modern EFIS would sort out that problem as well
Is there any way to do this if the aircraft is only for private VFR use
Closest Airfield: Mossel Bay
Has thanked: 1560 times
Been thanked: 2190 times
Re: Replacing steam on a certified aircraft
Unread post by Whirly »
MGL not, not sure about Dynon. He could look at the certified Garmin G5 or uAvionix AV30C, I like both, and they are not too expensive. However, it will take lots of paperwork and plenty moola to do, CAA, is involved.
Non certified, NTCA, is much easier. I flew with two Garmin G5s in my previous helicopter and now have 2 AV30Es installed in my current one. The G5s have a built-in GPS, the AV30s not (my Garmin 760 is connected to them though) , but I see the numbers better on the AV30s, they work great for me. I also added the temp probes, so now I see very accurate OAT as well as instant DA figures.
StressMerchant
Closest Airfield: Cab
Has thanked: 215 times
Been thanked: 388 times
Unread post by StressMerchant »
It's worth looking to see if the aircraft type is covered uner the STC-AML (Approved Master List) of the equipment manufacturer. If the kit is already covered under the AML, you may be able to get free use of the STC when buying the equipment. Not all National Airworthiness Authorities recognise STC-AMLs, but it's worth a read. If nothing else it may save some time with the installation instructions.
These users thanked the author StressMerchant for the post:
Rotor kop
Dweller on an errant planet
Seem like Dynon certified can do all he needs, they have a list of aircraft on their STC, so does Garmin, and uAvionix. Available panel space will also dictate.
Depends on how much he can or wants to spend.
Rotor kop
Closest Airfield: OR Thambo
Has thanked: 2889 times
Been thanked: 470 times
Unread post by Rotor kop »
Probably going to cost more than the aircraft value #-o unless he is very lucky and a STC and panel change will be free...
Vogoff
Argument with Heli Pilot.
Closest Airfield: FASD
Has thanked: 154 times
Been thanked: 241 times
Unread post by Vogoff »
Dynon do a very nice panel for the Seneca with auto pilot, ADSB, engine monitor and radios. But no GPS.
"Only" $41k excluding installation. Or around R800,000 at todays prices.
That's for a twin with all the bells and whistles. A basic system starts around $13k (R250k).
So they can probably do it. But I doubt "affordable" would be a word used in the conversation. Dual G5 or AV30s would probably be more cost effective.
These users thanked the author Vogoff for the post:
Rotor kop
Matthew French
ZU-DRO : Cubby Mk II
Lood
Closest Airfield: FAHV
Has thanked: 151 times
Been thanked: 801 times
Unread post by Lood »
Vogoff wrote: Mon Feb 17, 2025 1:20 pm Dynon do a very nice panel for the Seneca with auto pilot, ADSB, engine monitor and radios. But no GPS.
Absolutely.
Nothing in the South African TCA world has any sort of connection to affordable, unfortunately. I hear some numbers from time to time and it is simply unthinkable. Even a very minor upgrade can easily set you back, north of a hundred thousand.
Vogoff
Lood wrote: Mon Feb 17, 2025 1:50 pm Nothing in the South African TCA world has any sort of connection to affordable, unfortunately. I hear some numbers from time to time and it is simply unthinkable. Even a very minor upgrade can easily set you back, north of a hundred thousand.
My rough estimates for type certified avionics:
  • EFIS: R100k (2xG5) up to "how much you got"?
  • ADSB: R100k (if an internal GPS is used)
  • Backup (non primary) engine monitor: R150k
  • Panel mount IF GPS: R200k
By comparison I'm busy updating the panel in my Cubby. New EFIS, new radio, new engine monitor. No GPS maps because I have a phone. No ADSB yet. All less than R50k, thanks to MGL.
Jean Crous
Matthew French
Has thanked: 60 times
Been thanked: 1093 times
Unread post by heisan »
Just remember - if the goal is to get rid of the vacuum pump, then you will require 2 power sources. So either a dedicated battery backup solution (which most EFIS manufacturer's can supply), or one with built-in battery backup (IIRC AV30 has one?).
heisan wrote: Mon Feb 17, 2025 2:51 pm Just remember - if the goal is to get rid of the vacuum pump, then you will require 2 power sources. So either a dedicated battery backup solution (which most EFIS manufacturer's can supply), or one with built-in battery backup (IIRC AV30 has one?).
Yes it does, and you have to pay extra for the one in the G5.
My 2 x AV30Es (Experimental), when they just installed them. I will take a new pic, showing the Garmin GPS 760 too.
These users thanked the author Whirly for the post:
Rotor kop
The 2 x G5s (Experimental) in my previous Alo. I personally prefer the AV30s.
Rotor kop
Whirly wrote: Mon Feb 17, 2025 3:04 pm My 2 x AV30Es (Experimental), when they just installed them. I will take a new pic, showing the Garmin GPS 760 too.
What the AV30 cost?
RK,
Go to : www.uavionix.com
It will depend if you need the "E" or "C" one. Once you have ADS-B, it is able to display other traffic, and you can control your remote transponder from it too.
I have an AV-link on each installed too, allows upgrades to be downloaded wireless.
Rotor kop
mi'cmaq
Reaching altitude
Great information ; thanks to everyone who posted
Unfortunately my friends aircraft does not appear on the STC - AML (approved master list) of either Dynon, Garmin or uAvionix
