What aircraft is it?mi'cmaq wrote: Mon Feb 17, 2025 7:09 pm Great information ; thanks to everyone who posted
Unfortunately my friends aircraft does not appear on the STC - AML (approved master list) of either Dynon, Garmin or uAvionix
Agreed. If you fly (or intend to} fly IFR, having both vacuum and electric systems is essential. Vacuum pumps repairs and older vacuum driven instruments are much cheaper than modern instruments.heisan wrote: Mon Feb 17, 2025 2:51 pm Just remember - if the goal is to get rid of the vacuum pump, then you will require 2 power sources. So either a dedicated battery backup solution (which most EFIS manufacturer's can supply), or one with built-in battery backup (IIRC AV30 has one?).
It looks like the vacuum pump will have to be replaced +/- $ 600 ex USA ; the engine it is fitted to is a Lycoming O-235 of 115 HPmi'cmaq wrote: Mon Feb 17, 2025 7:09 pm Great information ; thanks to everyone who posted
Referring to only VFR. I might be wrong, but I think you can mark the AH as non-Op and still fly VFR as it is not required. Not sure if you can just remove the vacuum pump? Probably need a mod approval? Any AMO's on here that can give info?mi'cmaq wrote: Sat Feb 15, 2025 3:38 pm Enquiring for a friend whose vacuum pump has packed up on his certified two place aircraft
He would like to chuck out the old steam gauges along with the vacuum pump, regulator and hoses and replace them with a modern EFIS from MGL or Dynon ; also his JPI engine monitor has started dropping some digits and a modern EFIS would sort out that problem as well
Is there any way to do this if the aircraft is only for private VFR use
