wanted: diy spotwelding kit
Your models for sale or wanted. Posts with no movement after 120 days are deleted.
No commercial adverts please. If you wish to advertise in the commercial models section as above email: ads@avcom.co.za
Forum rules
Strictly no commercial adverts. For guidance on our views as to what construes commercial in nature, please click here. If the item is not your personal asset, you must post the contact details of the owner. You are also to ensure you have permission of that person to post their details. Where a template is supplied, all fields are mandatory. Non compliant posts will be deleted with no notice.
nicofly
Closest Airfield: fala
Has thanked: 37 times
Been thanked: 32 times
Unread post by nicofly »
Item Name: diy spotwelding kit
Description: [-o<
Condition:
Reason for buy: [-o< cannot buy lipo's :cry:
Shipping:can collect [-o<
Price: [-o<
Payment methods: EFT, Cash, No e-Wallet
Contact: by Private Message only please.
Pictures:
Or anyone that can help me build a simple one that is timed ? [-o<
FLY it like you borrowed it
rolfbartels
Closest Airfield: BRCC
Been thanked: 3 times
Re: wanted: diy spotwelding kit
Unread post by rolfbartels »
Battery Experts can build your pack.
else look on banggood, it will cost R300 and you'll get it in 2 weeks.
nicofly
Thanks but i lost my fair share of packages over the years
rolfbartels wrote: Tue Mar 18, 2025 11:46 am Battery Experts can build your pack.
Thanks i will look at it
Geutneut
Reaching altitude
Closest Airfield: Eros Airport
Has thanked: 3 times
Unread post by Geutneut »
Hey .. apologies to budge in ...
I been in this same boat / Quest / Hunt for the same thing 2 years back - about.. After buying 3 cheap 12V powered supposed Spot Welders, I eventually bought a decent one that works. Do not waste money on cheap tools. My dad told me this - but I thought I knew better.. .Turns out Dad knew better ;)
I bought a Sunkko 737G+ - and it is worth every cent. mucking around with cheap tools that say they do something they fail at attempting is not worth the time or the savings. Back then it set me back 212 USD, and an couple of grand in Rands for shipping.
Hope you get sorted though..
H9 Valiant 33cc EVO 33GX2 and Jnr Valiant
H9 Spitfire 60 - 115GK
H9 P40 Warhawk 50
TF Thunderbolt DLE 30cc
ESM "September Fury" 55RA DLE
Carl Goldberg "Rubin" - YS120FZ
Unbuilt Carf 1:4.2 Scale Spit & KOLM IL-150-3
nicofly
Geutneut wrote: Wed Mar 19, 2025 12:31 am Hey .. apologies to budge in ...
All opinions are welcome thanks. After months of thinking this over i also came to the conclusion that these pocket one's is going to bite one in the long run. But i cant afford your 3-4k welder either so the best compromise is to do it with a ( myplan at least) psu i have 2 two 67 amp 12v psu's that i plan to perhaps connect in series.
(If it blows it blows but i'm willing to try it)
Then i have a 90 000 uf 100v Cap bank that will be connected to the psu with a big starter solenoid i got the other day.
This is what i got at hand so i have to make it work whether or not its a good solution i need to make it work as its all i got.
If i can make it work hopefully it would last much longer than a pocket spot welder.
Problem is... i am not sure how to exactly put it all together in the best way to make it work. I mean i can solder and build things but i need some guidance...
And a control board from my research would also smoothen out things, but not sure where i can get one for cheap. I dont have extra to spend.
If only i knew someone that could help me put it together.
I have a hobby item or two i can give them to show my grattitude.
rolfbartels
It will BLOW LOL !!!!
I have to say I have a R300 spot welder and while it's not great and I have to put it on the highest level it actually works fine and does the job, as I said I have one like in the link, had it for 3 years and have packs I built with it still running.
https://www.banggood.com/Spot-Welder-DI ... mds=search
nicofly
rolfbartels wrote: Wed Mar 19, 2025 7:06 pm It will BLOW LOL !!!!
The hope is that the psu's might not blow if i add the massive cap bank as a buffer as well as a big fuse.
Then the solenoid too.
Yes, your timer is exactly what i want to add to the whole thing. The psu's and massive cap bank needs to just replace the 12v source.
If only i can get the timer board locally affordably and a schematic to hook my specific components up. That would be a helpful start.
Has thanked: 2120 times
Been thanked: 2162 times
PSU in parallel with capacitor bank
Pos to Post
Neg to Neg
A timer based on the NE555 IC with a power transistor to switch the solenoid will do the trick.
The timer will need it's own PSU as the weld will short it out.
These users thanked the author Ugly Duckling for the post:
nicofly
Paul Sabatier
Has thanked: 60 times
Been thanked: 1105 times
Unread post by heisan »
Just spitballing, but how about something like:
Add a 12V 5W lamp. Then you only need a 5W PSU (12V, 0.5A) and no timer (relay will automatically open when caps are discharged).
Only disadvantage is that it will take a second or 2 to recharge between welds. If it buzzes, producing very rapid pulses, then the lamp is too low resistance for the capacitor bank - replace it with a 100Ohm 1W resistor.
These users thanked the author heisan for the post:
nicofly
nicofly
Ugly Duckling wrote: Thu Mar 20, 2025 9:11 am PSU in parallel with capacitor bank
Pos to Post
Neg to Neg
[-o<
I was told the capacitors i have won't discharge quickly enough ? Perhaps the person was missing something ?
nicofly
heisan wrote: Thu Mar 20, 2025 10:03 am Just spitballing, but how about something like:
[-o<
Please have patience with my "sub standard" knowledge
(i am trying my best)
Am i more or less on the right track here ?
12V PSU = 0.5A would be OK - entire punch comes from capacitor bank.
LS1 = 12V 5W lamp (eg indicator lamp from Midas).
RY1 = solenoid
S1 = push button switch
C1 = capacitor bank
No need for timer boards or anything. BUT it assumes the capacitor bank has enough punch to do the weld on its own.
Also, this is spitballing - never tried this, but it looks like it should work.
nicofly
nicofly
Pos to Post
Neg to Neg
ok will just disregard what the other person said about the discharge rate of the caps and connect the cap bank to the 67 amp psu [-o<
Starter solenoid between psu and cap bank
Or starter solenoid between ic board and cap bank.
Does this order look right:
67 amp PSU ----> 10 000uf cap bank ---> starter solenoid-->NE555 IC--> welding rods.
(Button switch between Psu cap bank and starter solenoid)
The NE555 timer switches on the solenoid coil for the desired duration of weld.
Spend some time studying this info
https://www.build-electronic-circuits.c ... alculator/
https://www.electronics-tutorials.ws/wa ... ent-page-2
nicofly
Paul Sabatier
nicofly
Ugly Duckling wrote: Thu Mar 20, 2025 5:51 pm The NE555 timer switches on the solenoid coil for the desired duration of weld.
I will try my best to make sense of it thanks.
When i have the timer i will post actual pics of how i think it should be connected. For now i will look at the links you posted thank you.
These users thanked the author nicofly for the post:
Return to “Model Personal Classifieds”
