Ask George
- Avionics Master On
- Been thanked: 0
Re: Ask George
HI Hennie,
do you have the boost pump running? On a cool morning the egt,s will run slightly higher. 740 is ok. If the problem persists the fuel inlet port can be opend to a 3/32" diameter 2.38mm rather than the 2mm any larger the carb will flood.
len
len
- Been thanked: 0
Re: Ask George
Hi Wynand'
The standard wheels are 5" the larger wheels are 6". You cannot fit the spats to the larger wheels , the rims stay the same.
len
len
- Tree Tousand
- Closest Airfield: Swakopmund
- Been thanked: 55 times
Re: Ask George
just a thank you note to Karin and the crew at "George" for the assistance to get my aerie back in the air asap. It's service like that which is deeply appreciated.
- Flaps set for Take off
- Been thanked: 0
Re: Ask George
Hi Len,
Would like to know if Jabiru has any future development plans up their sleave for a fuel injected Jab motor?
Thanks
Johan
Thanks
Johan
Re: Ask George
Johan. Check this out:JOLO wrote:Hi Len,
Thanks
Johan
http://forums.matronics.com/viewtopic.p ... 19a395e949
- Six Tousand
- Has thanked: 32 times
- Been thanked: 16 times
Re: Ask George
Hi Len
I believe DFP is with you for a rebuild after being flipped on her back!
How about a thread with pics about the rebuild?
That could be educational to all off us...
- Been thanked: 0
Re: Ask George
Hi ben,
I would think it would be boring...... not much damage , bent noseleg broken strut and prop , wingtip and fin damaged. should be back in the witin 2weeks
- Fower Tousand
- Has thanked: 79 times
- Been thanked: 17 times
Re: Ask George
Done and I will test it next week Sunday on a X/C. Will let you know!Len alford wrote:there has been a s/b out on the 4xx and 160's which entails an extention to the bottom lip of the cowl , this produces more draw . A bit of experimenting with some ali plate and some self tapping screws. BTW have you canged from the original engine instruments?
Len
Thanks so far for yor help Len!
Groetnis
Francois Gouws
Francois Gouws
- Tree Tousand
Re: Ask George
Len, is there perhaps a way to determine the adequacy of the "rubber spacer set", those rubber (mine is red) doughnuts on the front wheel assembly? I was recently told by someone (who knows more about jabbies than I do) that the nose of my plane seems a bit low. It is quite possible that these doughnuts have been squashed into a smaller unit than what it's supposed to be. How can I check it? I could not find any specification in the manual.
thanks
thanks
- Been thanked: 0
Re: Ask George
hi henk,
yes the urethane spacer set does collapse over time (hard landing runway conditions time etc) If you pull down on the prop while chockng the front nose gear you shold see less than 10 mm of play. Colours are a S.A. thing and don't represent any specific designation. monitor closley otherwise you might be in for a prop. If you need more clarity ph 044-876 9991
Len
Len
- Tree Tousand
Re: Ask George
Thanks Len, will check when back in SA.
- Six Tousand
Re: Ask George
Len, could you please publish for us the correct service part numbers for the Oil filter, Spark plugs and Air filter?
And confirm oil service intervals are every 50 hours?
About the undercarriage gears & taildraggers :
Hello !
Are tricycles transformable in taildraggers ?
Thanks
Thanks
- Heli Pilot agrees to buy Super.
- Closest Airfield: Rustenburg
- Been thanked: 0
Re: Ask George
Hello Len,
Quick one on checking Carb Heat before take off from dirt strips. I was told that it might be a bit detrimental to engine life. (Sucking dirt into engine)
Advice will be appreciated.
GerritvR
ZU - EYN
GerritvR
ZU - EYN
