Ask George
Burner
Closest Airfield: LIMB
Has thanked: 86 times
Been thanked: 702 times
Re: Ask George
Unread post by Burner »
Len will give you a more technical answer, but even when the carb heat is pulled the air is filtered so as to prevent dirt and dust entering the engine.
ZuluBen
Has thanked: 32 times
Been thanked: 16 times
Re: Ask George
Unread post by ZuluBen »
Gerrit, Burner is correct.
Other than on your usual Cessna / Piper / Mooney / etc setup, the hot air on the Jabi is FULLY filtered, and you may do so without fear.
That is also the reason why you may control your mixtures with the carb heat for prolonged periods of time with no risk of contaminating the engine
Now on my Cessna and Piper, I would NEVER check carb heat on a dirt runway, as the air is unfiltered.
peterd
Reaching altitude
Has thanked: 14 times
Re: Ask George
Unread post by peterd »
hi zuluben
not always true. The earlier versions of filters do not filter the carb heat air duct. j400 etc. The reason has been to ensure you can fly with a blocked air filter by pulling the carb heat as a secondary air source. If you remove the filter cover you get a good idea if your system filters the carb heat air or not. In any event check the carb heat on gravel while taxiing if possible or on the preflight with the engine top cover off. You can feel if the spring loaded valve locks open.
cheers peter
ZuluBen
Re: Ask George
Thanks Peter!
Did not know that the earlier systems were different :oops:
I personally check the operation before start, you can feel the cam "pull over" and hear the mechanism operate.
ZuluBen
Re: Ask George
Len, you have to tell the story of the Jabi that you dragged out of the ocean after it has spend many hours floating and the restoration of that. That story is too good NOT to be part of the Jabi folklore!!
henk-indabush
Closest Airfield: Swakopmund
Been thanked: 55 times
Re: Ask George
Unread post by henk-indabush »
Minor matter - I had DNO at Legair for a service and minor cosmetic repairs, just before the Gariep fly-inn. They did a sterling job, =D> but I would like some advice form you Len. I had the flaps resprayed, since there were some seriosly deep "chafing" marks at the leading edges of both flaps, obviously from some dirt/stones/debris caught between the flap and the wing. The marks were app 4 - 5 cm in length , 1 - 2 mm wide, at 4 areas on each flap; and were through the paint and app 1 - 2 mm into the fibreglass. Unfortunately no pics of it.
I bought the plane like that, and checked that there was no debris in there, but it still bothered me, I could see it with each pre-flight, so had it repaired.
Since then, the plane has a marked vibration with full flaps. 1 Notch of flaps cause a minor vibration, full flaps more serious, but not that it affects performance. It's just a vibration which were not there previously. Also a "wrrrrr" noise which appears when extending flaps. No vibration, no noise with no flaps.
I wanted to get advice from Chris at Gariep, but unfortunately missed him. Is there something I can check myself?
Hennie van Zyl
Re: Ask George
Unread post by Hennie van Zyl »
As I understand it, the wings are not imported, but manufactured by the factory-
My leading edges on flaps-- same problem. I did not have it repaired. I'd love
to hear Len's comments as well.
Len alford
Avionics Master On
Re: Ask George
Unread post by Len alford »
Hi Henk
the flap viabration occured after repairs ? then I suspect that the bushings between the flap bolt and the hinge arm were not put back. these bushings are small. They are made up of 1/4 bundy tube 7mm long.Check this first.If the marks are there sand under the trailing edg of the wing and check the clearance with a piece of paper.
henk-indabush
Re: Ask George
Affirm Len, it occurred only after prepairs. Will check as you suggest and give feedback in about 2 weeks, once I got to the plane.
Thanks a lot, appreciate your advice.
Roger
Closest Airfield: FAPE
Has thanked: 407 times
Been thanked: 884 times
Re: Ask George
Unread post by Roger »
ZuluBen wrote:Len, you have to tell the story of the Jabi that you dragged out of the ocean after it has spend many hours floating and the restoration of that. That story is too good NOT to be part of the Jabi folklore!!
This one?
ZuluBen
Re: Ask George
=D> =D> What a pic! =D> =D>
Cannot repeat my first two words that I uttered after seeing that pic!
OK Len / Les, I know you are busy, but it is time now .... :)
ZuluBen
Re: Ask George
Skybound, you just HAVE TO post that pic under the "Write a Caption" heading on 123.45 :idea: =D> :lol:
Burner
Re: Ask George
http://www.caa.co.za/resource%20center/ ... 3/7641.pdf
Amazing story! Didn't know that it was restored hey... back in George on Sunday, if Len doesn't get a chance to reply on here will go find out more about the story and reply here!
Burner
Re: Ask George
Image one of Bearcat's great photos!!
Looks to have been a great repair job too... Have seen this aerie somewhere I think Kitty Hawk... and correct me if I'm wrong but wasn't it for sale in the classified here a while back too?? Great looking SP!!
wynand
Closest Airfield: FAHT
Has thanked: 26 times
Been thanked: 67 times
Re: Ask George
Unread post by wynand »
"After 6.5 hours of flying"
"Fuel exhaustion"
Gee, if he hadn't made a draai over the Indian ocean he would've made it.
Excuse my flippancy.
But seriously wow, what is the endurance of one of those aeries?
