ZU CYB Project
- Too Tousand
- Has thanked: 2 times
- Been thanked: 11 times
Re: ZU CYB Project
update!!!
fitted oil cooler and bracket with new hose and fittings. Also removed all the studs from the heads to fit 1 piece rap around exhaust manifolds. spent about 2 hours trying to get my end float set. had problems wit my shims, so waiting for new thinner shims from the agents tomorrow.
this bitch is almost ready to start
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
ZS-WPX (KR2)
- Too Tousand
Re: ZU CYB Project
Fitted exhaust manifolds and tapped extra hole for EGT probe for the no 1 . Now I have dual EGT using a skydat and 2 probes on the no 3 and no 1 exhaust outlets. Also have dual CHT using skydat.
Fitted new oil fittings and hoses for the oil cooler. Shims for end play will arrive tomorrow and then can finalize end play . Then I can assemble inlet manifold , carb and all the other accesories. should be ready to start early next week.
Also purchased a new oil breather.
sweet,sweet
Craig
sweet,sweet
Craig
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
ZS-WPX (KR2)
- Seven Thousand
- Has thanked: 62 times
- Been thanked: 1048 times
Re: ZU CYB Project
Looking good!
Is that an EMPI cooler from Volkspares? What size is it? (One of the last items on my shopping list!)
Thanks!
-justin
Thanks!
-justin
- Too Tousand
Re: ZU CYB Project
UPDATE!!!!!!!!!!!!!!!
I am extremely happy to announce. THE ENGINE STARTED FOR THE 1ST TIME TODAY. It sounded great. Oil pressure was very good and she started very easily after cranking it for a while to build up oil pressure. I haven't even set the timing 100% yet or set the air fuel mixture 100% yet and she is running so sweet. Really good feeling knowing I put in so much effort to get this baby running. She is all brand new now. Tomorrow we will put a nice groot fan onto the engine so that w ecan run it longer to set the timing and mixture 100%. Then I must install into cubby and finalize everything. Looks like she will be ready by end March.
PS
I have uploaded a youtube video of it running.
http://www.youtube.com/watch?v=h98TCqtwcGc
PS
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
ZS-WPX (KR2)
- Engine full power confirmed
- Closest Airfield: Stellenbosch
- Been thanked: 0
Re: ZU CYB Project
Craig well done boet!!! I know you worked your ass off on that motor. Really great job.
At this rate you will be flying before us C'mon CAA, make speeeed pleeeez!!!!!
HansGiant
ZU DXU
HansGiant
ZU DXU
The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man. - George Bernard Shaw.
- Closest Airfield: FAGC
- Been thanked: 2 times
Re: ZU CYB Project
Congrats Craig - she looks spotless! Good enough to eat a pizza off (Debonairs of course)
- Changing Underwear
- Has thanked: 111 times
- Been thanked: 148 times
Re: ZU CYB Project
She sounds AWESOME, tears of joy I tell you!!! Well done boykes, nearly time for some celebratory drinks with the boys at Volkspares!
- Seven Thousand
Re: ZU CYB Project
Congrats! Always nice when they fire up for the first time .
Soon you will be airborn!
- Too Tousand
Re: ZU CYB Project
Thanks guys for the nice words. I have uploaded another video of us setting the timing today. she is sounding and running very sweetly indeed. I put this groot fan infront to blow some cool air onto the heads whilst we were running the motor to set the timing.
Now I will be taking her and mounting the engine onto the cubby. Just waiting for my reduction drive and then can finalize.
cheers
Craig
http://www.youtube.com/watch?v=beUcUWcOJ3o
cheers
Craig
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
ZS-WPX (KR2)
- Too Tousand
Re: ZU CYB Project
update!!!!!
The cubby now has a new heart!!! very big thank you to Hans for helping me install the engine. Now all the nitty gritty stuff to be finalized. The Redrive arrives tuesday and then fit the prop , do all the wiring and then ready for some engine ground runs.
Craig
Craig
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
ZS-WPX (KR2)
- Too Tousand
Re: ZU CYB Project
update!!!
Due to the relocation of the oil cooler mounted under the sump instead of the cowl where the current scoop is, I have cut a section in the front cowl and will back it with a wire mesh grill from autosport to give it a nice finish. This will force air over the oil cooler then it will pass through it and escape out the back. I will use the current air scoop and funnel cool air to the air filter which is located at the top back of the firewall mounted on the special airbox/carbheat combo box.
The redrive arrived today so saturday will be a very busy day for me asembling all the bits and pieces. This aerie should be ready for test flight late march early april.
Over and out
Craig
Over and out
Craig
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
ZS-WPX (KR2)
