Example: Most number of loops in a single flight
Our fun RC record attempts.
Roger
Closest Airfield: FAPE
Has thanked: 281 times
Been thanked: 714 times
Unread post by Roger »
Challenge: Most number of loops in a single flight
Rules:
Must be in a single flight. Open to all forms of flight except line control. Powered by battery, nitro or free flight. Must be consecutive loops with no pause for repositioning in either axis. Only submit your attempt if it beats the last posted attempt.
General Discussion thread relating to this particular attempt (if applicable):
viewtopic.php?f=16&t=59128&start=0
Any discussion posted in this actual record thread may be deleted without any notice.
Attempt posts to include as minimum for consideration (cut and paste below into your submission):
Date:
Time:
Number of loops successfully completed:
Aircraft type:
Powerplant:
Power type (fuel mix/battery size/launch mechanism):
Witness: (no need to post phone details - PMs will be sent if deemed necessary).
Notes (add any pertinent info in respect of your attempt):
The challenger can add/subtract to this list and rules as they see fit. Once a challenge has been posted for longer than 24 hours the requirements should not be changed.
Roger
Re: Example: Most number of loops in a single flight
Date: 21 Feb 2010
Time: 15:12
Number of loops successfully completed: 360
Aircraft type: Dizzy 40 size
Powerplant: OS 46 AX
Power type (fuel mix/battery size/launch mechanism):Nitro 20%
Witness: Mr Count Crow
Notes (add any pertinent info in respect of your attempt): This was my 3rd attempt of the day - all previous attempts the wind had pushed me too much and had to reposition each time.
Note to submitters - please ensure your record exceeds the current record.
anthonyhugo
Closest Airfield: Crosswinds
Unread post by anthonyhugo »
Skybound wrote:Date: 21 Feb 2010
Time: 15:12
dude was this for real!? 360 loops are insane :)
Anthony Hugo
Crosswinds
SNIPER
Has thanked: 393 times
Been thanked: 42 times
Unread post by SNIPER »
Insane to say the least !!! =D> =D> =D>
Si vis pacem para bellum
All it takes for evil to prevail is that good men do nothing.
MARTIENS
Airborne from Unmanned field
Been thanked: 1 time
Unread post by MARTIENS »
In 1929 a Lady Pilot with the name Ingalls set up a record by doing 344 loops in succsesion with a Gipsy Moth, the immediate predecessor of the Tiger Moth !!! Should be easier with a model Aeroplane ?
If it is not fun doing,it is not worth doing !!!
SNIPER
MARTIENS wrote:In 1929 a Lady Pilot with the name Ingalls set up a record by doing 344 loops in succsesion with a Gipsy Moth, the immediate predecessor of the Tiger Moth !!! Should be easier with a model Aeroplane ?
I wonder if she wanted to? :lol:
Roger
anthonyhugo wrote: dude was this for real!? 360 loops are insane :)
Nah - was aiming for it to appear insane so that it would be viewed as being an example only. Will put up the same challenge as a real one.
