MOST TOUCH AND GO'S IN 10 MINUTES!
Our fun RC record attempts.
Crash Pilot
Priming
Closest Airfield: mrf
Unread post by Crash Pilot »
Alright,same as in the example,who has made the most touch and go's in ten minutes?Give the following:
Date:
Aircraft:
Power Plant:
Number of touch and go's:
Place:
Witnesses:
Vliegtuig engines werk met rook...As die rook weg is,is daar sekerlik n fout...
Owner- IceWorx Refrigeration Services
084 297 1000
http://www.iceworxrefrigeration.co.za
Spektrum DX9 ....and loving it!
HANGAR 9 Funtana 125
Johnathan Roberts
Mags On
Re: MOST TOUCH AND GO'S IN 10 MINUTES!
Unread post by Johnathan Roberts »
Pilot: Gareth Roberts
Date: 28.02.10
Aircraft: Shotgun 5000
Power Plant: GMS 26
Number of touch and go's: 66
Place:ELMAC (East London Model Aircraft Club)
Witnesses: Mark Nelson, Mike, Cliff Roberts, Bryn Roberts
Last edited by Johnathan Roberts on Sun Feb 28, 2010 7:40 pm, edited 1 time in total.
Johnathan Roberts
Mags On
Pilot: Johnathan Roberts
Date: 28.02.10
Power Plant: GMS 26
Number of touch and go's: 72
rangs4africa
Unread post by rangs4africa »
<<Moderated - was not higher than previous record.>>
skyhigh
Unread post by skyhigh »
Are there any rules as to what aircraft you can use?Can i make a attempt with a shock-flyer/parkflyer,electric engine? Just standard touch and goes,hell ill do it for fun anyway :D
