RADIO CONTROLLED POWER DURATION
Our fun RC record attempts.
Slinky
Closest Airfield: MKMAA
Unread post by Slinky »
Radio Controlled Power Duration,
1. Any internal combustion power plant or fuel driven reaction motor is allowed
2. No limit on size of engine
3. Maximum takeoff weight of 5Kg
4. Hand launching model is allowed
5. Fuel unrestricted
6. Timed from point of model becoming airborne to point of touch down.
7. Glide/motor off time to not exceed 1% of total flight time, if glide time exceeds 1%, flight time must be taken from when motor stops.
8. All landings to be within 200m from point of takeoff in order to qualify record.
9. Only one person allowed to control aircraft during attempt, except as below .
10. A co-pilot may control aircraft for a duration of no more that 5 mins per hour for pilot to refresh.
Pilot Name:
Co-pilot name:
Place:
Aircraft:
Power plant:
Duration:
Witness:
Comments:
My workshop is like a time machine.........
I go in for 5 minutes.........
And come out 3 hours later.
Welcome to the only sport where dope is not only legal, but often recommended!
rangs4africa
Re: RADIO CONTROLLED POWER DURATION
Unread post by rangs4africa »
Pilot Name: Alan Smith
Co-pilot name: Juanita Smith
Place: Jailbirds - Boksburg
Aircraft: Domino Trainer
Power plant: MVVS 40 size with tune pipe
Duration: 39min's 28 Sec's
Witness: Johann Geldenhuys, Reino Jacobs
Comments: first attempt, will be trying again soon.
Jase
Been thanked: 7 times
Unread post by Jase »
Pilot Name: Jason Barker
Co-pilot name: none
Place: Zululand Aero Modellers - Empangeni
Aircraft: CG Eagle 2
Power plant: SC 40
Duration: Just over 2hr 30min, Not sure if someone still has the exact records
Witness: Alan Verity, William Dicks, Wayne Usher and most other ZAM members
Comments: Used a sadle tank which carried an extra 1l of fuel, landed because TX batteries were looking very sad
rangs4africa
Pilot Name Alan Smith
co-pilot Juanita Smith
Witness Johann Louwrens & Randal Olsen
Place Barnstormers
Date 21/05/2010
Plane 60 size trainer asp91 fs 1.2 lt tank 14 x 10 prop
Time 2h 25min o8 sec
Polly
Unread post by Polly »
As far as I know the SA record is officially held by Andre Nortje of Boksburg with a time of 8 hours 43 minutes as witnessed and authenticated by Samaa. I have an article of the previous sucessfull record attempt which he beat. This was flown by Dion Le Roux also of Boksburg with a time of 8 hours 44minutes. Both attempts were flown at the old Rand Skyriders field and the same aircraft was used in both cases.
Vesparado
Closest Airfield: Not saying
Has thanked: 5 times
Been thanked: 35 times
Unread post by Vesparado »
Polly wrote:As far as I know the SA record is officially held by Andre Nortje of Boksburg with a time of 8 hours 43 minutes as witnessed and authenticated by Samaa. I have an article of the previous sucessfull record attempt which he beat. This was flown by Dion Le Roux also of Boksburg with a time of 8 hours 44minutes. Both attempts were flown at the old Rand Skyriders field and the same aircraft was used in both cases.
Flip.... #-o #-o ...what aeries were those? =D> =D> =D>
I say,Fly It like you stole it!
In The Haze
Closest Airfield: Brakkies
Has thanked: 4 times
Been thanked: 1 time
Unread post by In The Haze »
I don't remember this, will ask Andre next time I see him. If correct this was quite something. =D>
ITH
I guess that flirting with death sometimes leads to a date - ITH
......never send to know for whom the bell tolls; it tolls for thee. – John Donne
Experience is the name everyone gives to their mistakes. - Oscar Wilde
cabeng
Closest Airfield: Rotorua -NZRO
Has thanked: 10 times
Unread post by cabeng »
In The Haze wrote:I don't remember this, will ask Andre next time I see him. If correct this was quite something. =D>
AND ?????
Clearly Weekends are made in china . They simply dont last !
In The Haze
AND ?????
Ummh yes. :oops: tks for the reminder.
ITH
cabeng
:lol: :lol: :lol: ANNNNNDDDDDD!!!!!
is that memory in the haze ? :lol: :lol: :lol:
In The Haze
:lol: yes it is. Like the rest of me. Eisch you guys making me :oops:
Actually need medication, so maybe I should seek help. I'll make an appointment to see Dr Andre Nortje and kill 2 birds with one stone. 8) plan.
ITH
cabeng
In The Haze wrote::lol: yes it is. Like the rest of me. Eisch you guys making me :oops:
:lol: :lol: :lol: , the same one that flew Pylon many years ago :shock: :shock:
In The Haze
Yes, the same Andre I need to find out about the record you keep reminding me about, and the same person I keep forgetting to ask.:D He still flies pylon, together with all the same culprits, Russell, Trevor etc.
ITH
cabeng
LOL, ok , well im really curious about that record
knew him many many years ago , nice guy , serious about his racing back then , even after a guy seriously mince meated his arm , has a classic reaction and continued racing :lol: :lol: :lol:
so back to the record ??
Ill check back in a month :lol: :lol:
clivem
Closest Airfield: howick
Has thanked: 6 times
Been thanked: 11 times
Unread post by clivem »
just be sure of what he is doing - surgeons often remove things, you need something fixed not removed :lol:
#IamImac
Current Sponsors : Powerbox-systems, GP Engines, Falcon Propellors, Savox Servos, G-Force Pilots
http://www.cmchobbies.co.za - South Africa
https://www.AerobatX.co.uk - UK
