Most number of loops in a single flight
Our fun RC record attempts.
Roger
Closest Airfield: FAPE
Has thanked: 281 times
Been thanked: 714 times
Unread post by Roger »
Challenge: Most number of loops in a single flight
Rules:
Must be in a single flight. Open to all forms of flight except line control. Powered by battery, nitro or free flight. Must be consecutive loops with no pause for repositioning in either axis.
Attempt posts to include as minimum for consideration (cut and paste below into your submission):
Date:
Time:
Number of loops successfully completed:
Aircraft type:
Powerplant:
Power type (fuel mix/battery size/launch mechanism):
Witness: (no need to post phone details - PMs will be sent if deemed necessary).
Notes (add any pertinent info in respect of your attempt):
Lomcevak
Been thanked: 1 time
Re: Most number of loops in a single flight
Unread post by Lomcevak »
Date: november 2012
Time: afternoon
Number of loops successfully completed: 30
Aircraft type: aerobatic glider
Powerplant: zero
Witness: (no need to post phone details - PMs will be sent if deemed necessary). many as per video link below
Notes (add any pertinent info in respect of your attempt): loops could be unlimited , but height loss determines when you stop!!!
check my link, it was a world first with so many consecutive controlled flip/loops
http://www.youtube.com/watch?v=Ab6KB8sLE9M
