Some factory projects
stefan
Closest Airfield: FARA
Has thanked: 35 times
Been thanked: 170 times
Unread post by stefan »
Just thought I would post some factory projects on here also. Complete info on http://www.microlighters.co.za under aircraft specific discussions.
stefan
Re: Some factory projects
A new Jabiru 3300 powered Explorer in the making. Mogas's new baby and will aslo be used as a factory demo
stefan
Also in progress is the Red Barron. Going to Reunion Island. Powered by UL 260i
Rotor kop
Closest Airfield: OR Thambo
Has thanked: 2788 times
Been thanked: 449 times
Unread post by Rotor kop »
Very nice looking - presume Bush Baby? Has that undercarriage been made stronger in the last couple of years?
Mogas
Flaps set for Take off
Has thanked: 1 time
Been thanked: 6 times
Unread post by Mogas »
Hi Rotor Kop
These are Explorers. The one after the Bushbaby and sister ships to the bigger Safari.
Regarding the gear, problems have been seen where the uninformed strung the bungees too tight, bending axles, gear legs and in the worst cases damage to the fuselage itself. Correctly rigged the bungee gear is more than adequate in coping with hard landings. For those still unconvinced we do also offer the expensive and heavy Grove gear on initial or re-builds.
I see you are in Badplaas, just around the corner :D pop into the factory at Komati anytime.
Mogas
Sippin mogas
stefan
Some more pic's
stefan
The new cowlings and fairings has paid of. This aircraft is a serious performer.
Powered by a 912 UL with a two blade VP IVO.
Some figures.
Cruise 4300rpm IAS - 88mph TAS - 93mph
4500rpm IAS - 97mph TAS - 102mph
4700rpm IAS - 105mph TAS - 110mph
5100rpm IAS - 115mph TAS - 121mph
5200rpm IAS - 120mph TAS - 126mph
Top speed - 134mph @ 5500RPM Straight and level
ROC - 800ft/min
She is going to Rhino Park for now.
stefan
And for those pesimists here is some evidence
Return to “Bushbaby”
