Loop,Roll,Split S
Our fun RC record attempts.
Johnathan Roberts
Mags On
Loop,Roll,Split S
Unread post by Johnathan Roberts »
Rules:
Time starts from wheels rolling and stops at touch down.
Pilot must complete complete 1 loop,1 roll and a split S. Can be completed in any order.
Attempt posts to include as minimum for consideration (cut and paste below into your submission):
Pilot:
Date:
Time taken to complete:
Aircraft type:
Powerplant:
Power type (fuel mix/battery size/launch mechanism):
Witness: (no need to post phone details - PMs will be sent if deemed necessary).
Notes (add any pertinent info in respect of your attempt):
My time was
Pilot:Johnathan Roberts
Date:04/07/2010
Time taken to complete: 16 seconds
Aircraft type:Magic Fun fly
Powerplant: ASP 32
Power type (fuel mix/battery size/launch mechanism): 10% green
Witness: Mark Nelson,Gary Greenberg,Gareth Roberts
Notes:
YODA
Engine Cranking
Closest Airfield: George
Re: Loop,Roll,Split S
Unread post by YODA »
Pilot: JACO BOTHA
Date: 16/10/2010
Time taken to complete: 8.3 SECONDS
Aircraft type: SHOTGUN 5000 PRO
Powerplant: WEST 36
Power type (fuel mix/battery size/launch mechanism): 10% PINK
Witness: (no need to post phone details - PMs will be sent if deemed necessary). FRANS VAN NIEKERK (ICE)
A PILOT IS ALWAYS OPTIMISTIC!!!
