Jabiru Service Bulletins
BigglesSA
Has liked: 23 times
Re: Shadow Lite SL8 Hydraulic Lifters 14 December 2010
Unread post by BigglesSA » Tue Dec 14, 2010 10:54 am
Groetnis
Francois Gouws
Pete
Has liked: 55 times
Been liked: 43 times
Re: Jabiru Service Bulletins
Unread post by Pete » Sun May 22, 2011 12:50 pm
Cyl base nut changed..
ZuluBen
Unread post by ZuluBen » Sun May 22, 2011 1:12 pm
Thanks Pete, much appreciated!
I believe especially the 4 cylinder engines used in training schools are more affected.
Interesting to note the recomendation to rather have a "cruise climb" setting, with more speed and less rate of climb to assit with cooling, and also interesting to note their recommendation that during climb higher RPM is preferrable, as it places less stress on the engine.
Len alford
Avionics Master On
Unread post by Len alford » Sat May 05, 2012 11:28 am
Service bulletin SL10 Circlips
wynandc
Power off Glide
Unread post by wynandc » Sat May 05, 2012 11:54 am
Len alford wrote:Service bulletin SL10 Circlips
Tx Len - interesting! My plane (DWR) was done at George in Jan. 2012. It got four new pistons. As I understand your SB, my plane is affected by the SB as the SB reads "... as from Jan. 2011..."
Must I assume DWR must come back for new circlips? (Seems that the 2200 engine uses "wire" clips and not circlips?).
Wynand
Not flying for seven days makes one weak!
BigglesSA
Has liked: 23 times
Unread post by BigglesSA » Sat May 05, 2012 1:17 pm
Okey....
This means my plane also falls within this SL. This means that it may or may not have the affected circlips fitted????
My take on this:
Indicated man hours for this inspection is 7 hours times the R375 per hour is R2625 WELL spend for peace of mind flying in the future in my opinion. In the same time this will also be a chance to have a good internal inspection of other parts as well in the same go!
No biggy!
Thanks Len.
Groetnis
Francois Gouws
BigglesSA
Has liked: 23 times
Unread post by BigglesSA » Sat May 05, 2012 1:22 pm
Wynand, as I understand the wire ones were discontinued around the same time in both 2200 and 3300 engines.
Below link to publication on Jabiru Australia site about clips:
http://www.jabiru.net.au/images/Piston_Circlips.pdf
Groetnis
Francois Gouws
wynandc
Power off Glide
Unread post by wynandc » Sat May 05, 2012 4:57 pm
BigglesSA wrote:Okey....
My take on this:
No biggy!
Thanks Len.
Hey man! I just paid for the full treatment... Must I pay again? :cry:
wynandc
Power off Glide
Unread post by wynandc » Sat May 05, 2012 5:09 pm
BigglesSA wrote:Wynand, as I understand the wire ones were discontinued around the same time in both 2200 and 3300 engines.
Thing is on Friday Charlene (Jabiru) said to me Len (Jabiru) said I do not have to worry - my plane has wire clips... now I just need confirmation!
ZuluBen
Unread post by ZuluBen » Sun May 06, 2012 12:15 am
Thanks Len
I agree with Biggles, small price to pay for peace of mind.
You guys do not want to know how much 9 little pipes and a few O rings cost me on my Cessna... :cry:
ZuluBen
Thanks Len
Marius Schrenk
Has liked: 188 times
Been liked: 121 times
Unread post by Marius Schrenk » Mon May 07, 2012 12:33 pm
Must be quiet a lot if you mention it twice :roll: :lol:
ZuluBen
Unread post by ZuluBen » Mon May 07, 2012 4:17 pm
Dont make me start crying all over again..... :cry: :cry: :cry: :cry: :cry:
Still love my Jabbie the most :wink: 8)
dak
Power on stall
Closest Airfield: Panorama
Unread post by dak » Mon May 07, 2012 9:50 pm
Phew ... a sensible SL =D> Thanks Len.
Was scared it would affect factory assembled engines, thus introducing risk of rebuild errors.
Bit nasty for the chaps that have recently had work done.
I did see a recent post on an Australian blog where a chaps engine suffered the same fate as ZB's
just 12 hours after top-end overall. Seems the AMO made the Circlip mistake.
I think the factory should colour code the things so there is no doubt how they should be fitted.
ZU-MEL
bluesmancoops
Unread post by bluesmancoops » Tue May 08, 2012 4:14 pm
have just had the 1000 hr overhaul plus blueprinting etc at nearly R30k only 3 weeks ago, and am I now expected to pay for a trip to Jabiru plus an inspection due to incompetence by an AMO????
Surely this should fall under some guarantee - If you take your car in for new rings and a week later they say they might have put the wrong rings in - would you expect to pay for their error??
Mike Cooper
Flying is not a habit ... it's an addiction
