Savannah 'S'
Italian designed, all alumunium, STOL aircraft
Rob K
Re: Savannah 'S'
Unread post by Rob K » Mon May 02, 2011 12:07 pm
Some pics from Friedrichshafen 2011.
SAFETY FIRST AVIATOR
LDV
Closest Airfield: Pietersburg Civil
Has liked: 21 times
Re: Savannah 'S'
Unread post by LDV » Mon May 02, 2011 1:33 pm
ONGELOOFLIK !!!
John throttle on the left ?
Leon
John Waterson
Power off stall
Re: Savannah 'S'
Unread post by John Waterson » Thu May 05, 2011 3:09 pm
I see that Leon
I am sure we can do the same for you. Here a photo of the new demo with reg and decals superimposed to give you some idea of what it will look like.
John
Savannah - All alluminium, STOL,
The Bakkie of the Sky
Take off 50 m
Cruise 100 mph
Stall with flaps 30 mph Ph 043 7321 321
John Waterson
Power off stall
Re: Savannah 'S'
Unread post by John Waterson » Sun May 08, 2011 5:36 pm
Getting Type Acceptance on the Savannah S is proving rather more difficult than we anticipated. The previous variants were accepted based on the British BCAR-S and FAA LSA-S standards. The only acceptance that we have to work on for the S is the German LTF-UL. So far one month since we started and we have an aircraft complete and not able to fly.
Take off 50 m
Cruise 100 mph
Rob K
Re: Savannah 'S'
Unread post by Rob K » Sun May 08, 2011 7:34 pm
LDV wrote:ONGELOOFLIK !!!
Leon
Why do you want to put the throttle on the left Leon?
You going to end up cross-handed trying to change frequencies and so on.
Rob
John Waterson
Power off stall
Re: Savannah 'S'
Unread post by John Waterson » Mon May 09, 2011 9:06 am
Hi Rob
Leon has opted for dual sticks, he wants the same configuration for left and right seat. Like me, he is uncomfortable with reversing hands (throttle and stick) when on the co-pilot side. take a look at Skykit's solution to pedal position.
John
Take off 50 m
Cruise 100 mph
Callie Calitz
Closest Airfield: Saldanha
Re: Savannah 'S'
Unread post by Callie Calitz » Sat May 14, 2011 11:40 pm
:D Baie bly ek het hierop afgekom, die "S" gaan n wenner wees en teen die genoemde prys kyk ek met ander oe na die mark!
Savannah S
John Waterson
Power off stall
Re: Savannah 'S'
Unread post by John Waterson » Sun May 15, 2011 7:47 am
Mooi ne ! :)
Take off 50 m
Cruise 100 mph
LDV
Has liked: 21 times
Re: Savannah 'S'
Unread post by LDV » Sun Jul 10, 2011 6:36 pm
John
Type Acceptance , perhaps you must take a trip to JHB and connect with the guys that design and build aircraft in seven days and fly them around the world !!! They seem to have very good connections.It seems to me that you guys are part of the LAST OUTPOST !
Good Luck
Leon
LDV
Has liked: 21 times
Re: Savannah 'S'
Unread post by LDV » Thu Jul 21, 2011 8:58 am
John
Photos of completed S PLEASE !
Leon
Agent Cooper
Re: Savannah 'S'
Unread post by Agent Cooper » Fri Oct 28, 2011 7:53 am
John something I picked up from the pix in Deutschland by Rob is that now there are 2 joysticks, that I like is that to be standard in all "S" models.
Must say I also like the throttle on the left but the flying from the right seat I also want a left hand throttle.
Are you able to show me the baggage space on one of you pix or drawings please John and where located.
Love thre BLUE paint job.
Property Investment http://www.coopers.co.za
Be nice to your children as they choose the old age home you have to go to one day.
Has liked: 1160 times
Been liked: 441 times
Re: Savannah 'S'
Unread post by ACE MAN » Sat Mar 23, 2013 9:10 am
JW airborne in +-20m! FAWR
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
AndyCAP
Re: Savannah 'S'
Unread post by AndyCAP » Sun Jun 30, 2013 10:37 pm
Take a look at Skykit's solution to pedal position.
John
DualPedals LR.jpg (87.49 KiB)
Hi John can you explain the significance of this pedal arrangement? Thanks
John Waterson
Power off stall
Re: Savannah 'S'
Unread post by John Waterson » Mon Jul 01, 2013 10:09 am
Hi Andy CAP
The Savannah seats are not adjustable so you are left with two options if you don't fit comfortably into the cabin with respect to seat - rudder pedal distance. Either you pack in foam pads behind the seat, but this has limited effect as you will shorten the seat base if you pack in too many. Or you make the rudder pedal assembly adjustable back and forth which is what Skykits have done. We have a similar arrangement should a customer require it. This is of course if the three optional fixed positions are not suitable to the customer. Where the adjustable pedals are realy useful, is when the aircraft is being used as a trainer and pilots and instructors of different heights are using the aircraft. Like when you get into your motor car after you wife has adjusted the seat.
Take off 50 m
Cruise 100 mph
AndyCAP
Re: Savannah 'S'
Unread post by AndyCAP » Mon Jul 01, 2013 6:17 pm
Thanks for the clarification John.
In my case Ideally I would want a footwell box built into the engine compartment to move the pedals even further forward !!:oops:
A few years ago I got into Rob K's Savannah VG XL. Can you recall if his plane hat the pedals in the most forward position, Or would there be scope to move them forward a bit more ?
Return to “Savannah”
