the Cri-Cri!
flightmaster
the Cri-Cri!
Unread post by flightmaster » Mon Aug 16, 2010 12:11 pm
Haha, if you've seen this plane then you would laugh with me! :lol:
Although, I absolutely love this airplane! it's the smallest twin airplane with a flight range of about 600km's!!
Travels at about 160knts!
This is a perfect home project airplane, I definitely plan on building one! It's most aluminum with two 15hp engines,
yes you read right, two 15hp engines!! Like I said I love this little twin engine plane!
It's perfect specially for farmers or someone that enjoys to fly for really cheap!
Some aviators even use little jet engines instead of the 15hp petrol engines!!
I have the plans for this plane if anyone is interested.
[url]ttp://www.tom-style.net/mt/archives/images/cr ... allery.jpg[/url]
ZuluBen
Re: the Cri-Cri!
Unread post by ZuluBen » Thu Aug 19, 2010 7:42 pm
Now if someody could find and import a few "quick build kits", I would be first in line to place an order! =D>
George
Re: the Cri-Cri!
Unread post by George » Thu Aug 19, 2010 8:03 pm
ZuluBen wrote:Now if someody could find and import a few "quick build kits", I would be first in line to place an order! =D>
Ditto... :oops: :oops: :oops:
grostek
Re: the Cri-Cri!
Unread post by grostek » Thu Aug 19, 2010 9:18 pm
Here is a link to a guy in NZ bulding one from scratch and he has the capability to produce kits.
http://www.homebuiltairplanes.com/forum ... nz-21.html
Kind regards,
Gunter Rostek
calypsoSA
Re: the Cri-Cri!
Unread post by calypsoSA » Fri Aug 20, 2010 8:00 am
I wanna plastic one
flightmaster
Re: the Cri-Cri!
Unread post by flightmaster » Fri Aug 20, 2010 11:28 am
Just build your own from scratch. use the plane's designs as an idea, but come up with your own. Like what I said, I can supply you with the plans for FREE.
Use your imagination....Learn about building aricraft, balancing, constructing etc etc....Learn about Airfoils, Types of materials...
Then the plans will make more sense.
At this moment I'm working on a plan to build a very basic ultralight. It'll probably not cost more than R4000 to construct.
George
Re: the Cri-Cri!
Unread post by George » Fri Aug 20, 2010 12:25 pm
I can't afford it. :oops: :oops: :oops: :oops: :oops: :oops: Time costs money :lol: :lol: :lol: :lol:
Jan
Closest Airfield: MOSSELBAAI
Has liked: 13 times
Been liked: 59 times
Re: the Cri-Cri!
Unread post by Jan » Fri Aug 20, 2010 1:07 pm
The latest is a Cri-cri with FOUR electric motors. charge it and it will go for about 30 minutes :o
These users liked the author Jan for the post:
Sundownerman
Flying is about discipline!
AP325
calypsoSA
Re: the Cri-Cri!
Unread post by calypsoSA » Mon Sep 13, 2010 7:35 am
ZuluBen
Re: the Cri-Cri!
Unread post by ZuluBen » Mon Sep 13, 2010 7:43 pm
Bugger logging Twin time, you can now log Multi engine time :lol: =D>
Elva
Re: the Cri-Cri!
Unread post by Elva » Mon Sep 20, 2010 11:55 am
I see that an electric powered one has also flown....and it is a 'plastic' plane...
Theuns v V
Been liked: 272 times
Re: the Cri-Cri!
Unread post by Theuns v V » Mon Sep 20, 2010 5:06 pm
If I look at the plane, I would deffenately build it as per plan from Allu sheet and extrution.It is so small that I believe it will by far be the cheapest and fastest way to build the airframe VS. Plastics.
There should not be mpre than a few sheets of 2024 in it.
Where can I get plans for this thing?
T
angelwingsthesecond
Re: the Cri-Cri!
Unread post by angelwingsthesecond » Mon Sep 27, 2010 10:40 pm
T
I have a set of plans I will give you, maybe we can build one together?
This is what I do, to pay for my flying. Check out http://bit.ly/Avcom
flightmaster
Re: the Cri-Cri!
Unread post by flightmaster » Sat Oct 02, 2010 10:02 pm
If you read my post that started this thread, you would've read that I can supply the plans for you absolutely free......
Theuns v V
Re: the Cri-Cri!
Unread post by Theuns v V » Sun Oct 03, 2010 9:29 am
flightmaster wrote:If you read my post that started this thread, you would've read that I can supply the plans for you absolutely free......
Thanx. Just one thing to remember. If you want to build it as a stock standard plans-built cri-cri, the caa will require a letter from the manufacturer of the kit or plans stating that the unique plan # was not issued to anyone else.
T
