Fastest Electric ARF
Our fun RC record attempts.
liaan
Circuit re-established
Has thanked: 60 times
Been thanked: 26 times
Unread post by liaan »
Challenge: Fastest ARF electric
Rules:
Must be ARF/Kit, must be electric. 2 Runs must be recorded via GPS. Radar, dopler or simular. The 2 runs must be within 20km/h, the fastest counts.
General Discussion thread relating to this particular attempt (if applicable): none yet
Attempt posts to include as minimum for consideration (cut and paste below into your submission):
Date: Aug 2010
Time: ~10am
Speed: 242km/h
Aircraft type: Great Planes Revolver.
Powerplant: Suppo 4120
ESC: Suppo 80A HV
Battery: Revo 9s1p 3300mah
Prop: EMP 11x12 (modified 12x12)
Recording: GPS, Graph attached
Notes (add any pertinent info in respect of your attempt): about 10km/h wind
bla bla fishpaste
I need spell Checker
wingdragon
Re: Fastest Electric ARF
Unread post by wingdragon »
Hi, seems a bit dubious, from 110km/h to 242.99km/h in 0 secs? :?
liaan
Welkom to GPS speeds.... it only polls every so often, and you pickup qoute a lot of speed from going vertical down to horizontal all sudden.
remember vertical down - 0 ground speed, then pull 90 degree and all the vertical speed (0km/h ground) converts to ground speed.. so you can actually "accelarate" quite fast
L:
bla bla fishpaste
wingdragon
Ok, cool! understood. 8)
Marnu Bothma
Reaching altitude
Closest Airfield: Midwest model club Potch
Has thanked: 1 time
Been thanked: 1 time
Unread post by Marnu Bothma »
Mini Sundowner
motor ?
Esc?
Batery; 5500mAh 90c nano tech
Speed; 388kph
liaan
Hi Flying Mad
How was this recorded, and what motor /prop did you use?
I stopped flying ages ago, so don't really care if record has been smashed, just like to keep it real ;-)
L:
bla bla fishpaste
Marnu Bothma
Reaching altitude
Has thanked: 1 time
used a cell phone twice and a gps system both were the same each test. dont know the specs of the motor as its not my plane.
Buks Coetzee
Hee Hee I'm Flying
Closest Airfield: Paradise beach
Unread post by Buks Coetzee »
What is the best and cheapest way of measuring the speed ?
I have a Funjet Ultra and would love to know at what speed it runs How do you measure it with a cellphone ? We estimate it runs at about 250km/h Do i need to get a "spietkop" to come and help ?
I dont like them that much ......
Keep calm and rotate !
liaan
Buks Coetzee wrote:What is the best and cheapest way of measuring the speed ?
Google Doppler affect or measure speed using doppler..
You simply record few passes close to microphone and record the noise .. (cellphone does work) Then you can download the program and analyze the speed using the noise
Howto Vid: http://www.youtube.com/watch?v=K7bCuiDN5Xs
L:
bla bla fishpaste
Buks Coetzee
Hee Hee I'm Flying
Cool
Will give it a try
Thanx
Buks Coetzee
Hee Hee I'm Flying
Had a look at the video link Awesome .........
garymac
Finals (unmanned)
Closest Airfield: tzaneen
Unread post by garymac »
Hi all i decided to modify an f16 60mm fan jet i covered it in solar film and remove the fan and fix an out runner motor with prop on the back of the jet and clock it at 244km.
Date: 17 Aug 2014
Time: 15:00
Speed: 244km
Aircraft type: f16 foam 60mm fan jet
Power plant: scorpion 2221-10
Battery:Gen ace 14.8 2200mah
Prop: apc 5.5x4.5
gps : garmin
Wind: no
Dean
Closest Airfield: Back yard
Unread post by Dean »
If you have an android phone search for RC Velox in the play store, it's a free download.
I've used it a couple of times, very nice doppler app.
Fly, crash, repair, repeat!
Dean
App was removed from the play store. :(
garymac
Finals (unmanned)
I am using an garmin sports watch you can get them at most sports shops but they are not cheap I paid at the time almost 2k
