M20J Static drain
TerryE
Been thanked: 1 time
M20J Static drain
Unread post by TerryE »
Ok, I give up,
Where do I find the static drain - I found what looks like it could be a drain under the Fuz, near the battery vent and drains, but it does not move and I didn't want to force it.
A superior pilot uses his superior judgment to avoid situations which require the use of his superior skill.
Frank Borman (Commander of Apollo 8 ) - Flying Lessons, Federal Aviation Administration, January 8, 2008
Lood
Closest Airfield: FAHV
Has thanked: 148 times
Been thanked: 766 times
Re: M20J Static drain
Unread post by Lood »
Maybe take off the side cover that gives access to the battery and have a look see inside with a torch. I'm not sure where the static vents are on a J, but you would probably be able to follow the static lines and maybe they'll lead you to the drain :?
TerryE
I gave the problem to our AMO, he stripped the drain valve, found it gunked up and siezed, but cleaned up nicely and working well. Drain is under the battery compartment.
Chrisk7
Mags Dead Cut
Has thanked: 2 times
Unread post by Chrisk7 »
It is situated on the belly under the tail cone access door
andrem
Has thanked: 29 times
Been thanked: 45 times
Unread post by andrem »
I checked my J and it doesn't seem to have one...
Lood
I'm not sure whether change were introduced with the J, but my F has the drain and my common sense tells me that although we'll probably never use it because we fly mainly VFR, it should be there somewhere - just in case.
andrem
I'll check with the AMO at MPI time in June, POH also refers to it, so should be there.
andrem
Okay, I found it, under the empenage door where the battery is kept...
Return to “Mooney”
