ZUYAK
An informal register and background to South African aircraft. Please take the time to read the 'Before you post', or your entry could be deleted.
BONNIE MAD
Been thanked: 8 times
ZUYAK
Unread post by BONNIE MAD »
1987 YAK 52
Performance
Maximum level airspeed 164 Kts
Range (10% reserve at 105 Kts) 280 NM
Stall speed, engine at idle,
Erect flight 60 Kts
Inverted flight 76 Kts
Flaps extended 55 Kts
Takeoff run (Standard Atmos.) 585 ft
Landing run " " 975 ft
Limitations
Never exceed speed VNE 230 Kts
Maximun airspeed at max Gs (+7/-5 G) 197 Kts
G limits +7/-5
Maximum gear extended speed (VLE) 110 Kts
Minimum speed Erect flight 71 Kts
Inverted flight 93 Kts
Maximum inverted flight time 2 mins
NOTE:
Allow three minutes of normal errect flight after each two
minutes of inverted flight to allow the oil to cool.
Ceiling 13000 ft
Minimum fuel qty for aerobatic flight 20 litres
Engine Data
Vendeneyev M14P Engine:
Cooling system air/fuel
Number of cylinders 9
Propeller reduction ratio 0.658
Compression ratio 10.6:1
Fuel type 91/155
Octane number >91
Carburetor type Pressure
Dry weight 471 lbs
Engine Limitations
Maximum time at max power:
Takeoff 5 mins
At max rpm 1 min
All other times No limit
Inverted flight 2 mins
Maximum allowable rpm 2950 (101%)
Minimum allowable rpm 700 (24%)
Time from idle to max rpm < 2 secs
Power settings
Rating HP RPM % Fuel Consumption Blower Outlet Pressure (mmHg)
Take Off 360 2900 99% 285-315 grams/HP/hour 125 - 15 (surplus)
Nominal I 290 2400 82% 280-310 95 -15 (surplus)
Nominal 2 240 2050 70% 265-300 75 -15 (surplus)
Cruise 1 .75 of N2 1860 64% 210-230 735 mmHg +/-15 (absolute)
Cruise 2 .6 of N2 1730 59% 215-235 670 mmHg +/-15 (absolute)
Aerodynamic data
Engine torque 1215 ft lbs
Best climb angle (at 80 kts) 12 degrees
Glide angle (Gear & Flaps Up) 7:1 at 93 Kts
Engine/prop static thrust 1212 lbs
Roll rate 140 deg/sec
Aerobatics
The Yak 52 is permitted to perform all the maneuvers listed in the Aresti / FAI catalog with the exception of ( ?? tail slides. ??)
MEN WERE MEANT TO RIDE WITH CLOUDS BETWEEN THEIR KNEES
Lood
Closest Airfield: FAHV
Has thanked: 129 times
Been thanked: 701 times
Re: ZUYAK
Unread post by Lood »
Lekka Alisdair - wys bietjie pics van die panel ook. Wonder of die Yak dit eendag sal maak Colesberg toe :?: :? Die Bonnie sukkel maar... :twisted: :P
BONNIE MAD
Re: ZUYAK
Die Yak het net twee uur endurance teen 115kts so ek sal planne moet maak met brandstof.Se net dan kom ons.
Return to “Our Register”
