Heli Hovering Duration.
Our fun RC record attempts.
pietermu
Closest Airfield: www.prf.co.za
Been thanked: 1 time
Unread post by pietermu »
Attempt: HOVERED Hirobo SDX for 22 minutes, Engine OS 50SX H with Funkey pipe, Std tank and header tank, 600 CF Funkey blades, NiMH 4200mAh, Futaba gear.
Where: SA modelsport, Benoni
When: November 2011
Landed when header tank was half empty.
www.easyup.org.za - Easyup R/C Skydiving
cabeng
Closest Airfield: Rotorua -NZRO
Has thanked: 10 times
Re: Heli Hovering Duration.
Unread post by cabeng »
That is a long time , For sure , so I assume some FF would disqualify one from this accolade?
Clearly Weekends are made in china . They simply dont last !
pietermu
cabeng wrote:That is a long time , For sure , so I assume some FF would disqualify one from this accolade?
:lol:
Ok Alex even when the machine is flown it still gives 20 minutes of flying.
I specified the Hovering because that is where the you will get the endurance from.
NB I would love to do a cross country with it to get a feel for distance it can reach :idea: :idea: 8-[ 8-[
:?: New Thread :?: :roll:
cabeng
WEll at 60kmph you looking at 20 km , it is unlikly you will go any quicker than that , not very fuel efficient these helis
Turbonator
Engine Started
Has thanked: 2 times
Unread post by Turbonator »
pietermu wrote: Wed Apr 18, 2012 1:03 pm Attempt: HOVERED Hirobo SDX for 22 minutes, Engine OS 50SX H with Funkey pipe, Std tank and header tank, 600 CF Funkey blades, NiMH 4200mAh, Futaba gear.
When: November 2011
Is this where Henke used to operake from? He was a Robbe agent/ I whould like to chat to him as I'm resoring two Robbe Nona Cuato helis
pietermu
Yes
Closed shop.
