What was your max groundspeed?
marcgerm
Fuelling up
Closest Airfield: FAPM
Re: What was your max groundspeed?
Unread post by marcgerm »
Nice Lood, What power settings did you use?
Lood
Closest Airfield: FAHV
Has thanked: 153 times
Been thanked: 808 times
Unread post by Lood »
I was at FL095, WOT, 2450 rpm and 75 deg ROP.
The wind was right on my tail at around 50kts. It's the second time I've encountered this type of conditions, on this route. Last time I did 186kts straight & level with 201kts in a 500ft/min descend.
Chrisk7
Mags Dead Cut
Has thanked: 2 times
Been thanked: 1 time
Unread post by Chrisk7 »
Some 2 years ago Lila and I returned from FACT and we saw 232kts FL110 S&L Lop. She took a photo of GPS, will see if I can dig it out somewhere. If I recall correctly we did the flight in about 50mins. Took off from FACT before an approaching cold front.
andrem
Has thanked: 34 times
Been thanked: 77 times
Unread post by andrem »
Lekker Chris! 232kts! Not bad at all!
jvg
Taxiing
Closest Airfield: Fawb
Unread post by jvg »
234knt
Faup to fawb 2,5 hrs total time
Sundownerman
Rotating
Has thanked: 31 times
Been thanked: 6 times
Unread post by Sundownerman »
Went for an afternoon flight in FZE (M20G - 180HP O-360 Lyc, with a 3 Blade Hartzell prop) - to fly a 4 point GPS run to measure G/S
Lovely smooth flight - in the JHB inversion smog
100 Litres fuel + 85 kg's peelot + Empty Weight 1,705 pounds (775 Kg's)
Power Settings 2500RPM, 23" MP, Mixture 50 Deg ROP, Indicated Airspeed = 122 Knots
Still working out the fuel flow/consumption rates
GPS GS Readings were
N = 142 Knots
W = 132 "
S = 128 "
E = 130 "
Averaged out at 133 Knots
Nice little aerie to fly - approaching on finals at 70 Kts, over fence at 60 Kts = :D :D
Lovely Flight!!
“Every time I Fly - I’m “Really Living” and “I’m in my Element” 😎
“It’s where I know I’m meant To Be” 🦅
Return to “Mooney”
