Fuel tank leak
TerryE
Been thanked: 1 time
Fuel tank leak
Unread post by TerryE »
They say that if you own a Mooney, you will have to deal with a fuel tank leak at some point, and my time seems to have come.
Looks like the left wing is leaking when filled to 20 gal, so I suspect it is on the outboard end.
My usual AMO is quoting R2 k in materials and approx 25 hours labour per side, So I have a few questions
1. Does this quote sound reasonable ?
2. Any recommendations, success stories on tank reseals / AMO's to use ?
3. Are bladders a viable option ?
I have also now heard that leaks can be caused by leaving the tanks low, as the sealant can dry out. We always refuel before flight, so that you can choose your fuel load, should we change to leaving her full ?
A superior pilot uses his superior judgment to avoid situations which require the use of his superior skill.
Frank Borman (Commander of Apollo 8 ) - Flying Lessons, Federal Aviation Administration, January 8, 2008
Lood
Closest Airfield: FAHV
Has thanked: 148 times
Been thanked: 766 times
Re: Fuel tank leak
Unread post by Lood »
Hi Terry, been there and had one tank completely stripped and resealed at the end of last year. So, I know exactly what you're going through. :(
Firstly, if your tank has never been repaired, or patched in the past, you might get away for a short while by having it patched. This will not cost an arm and a leg, but also, it will not last, unfortunately.
The only way is to have it done properly by doing a complete strip and reseal. It is very important to have this job done by somebody with experience - not only on sealing fuel tanks in general, but on Mooney tanks in particular. There are quite a few horror stories around about complete strip and reseal exercises that have gone bad due to inexperience and simple mistakes.
The quote sounds about right. Mine was done last year at SA Mooney for R20k, IIRC and I supplied the sealant. It is a huge, huge task and over in the US, the cost is around $8k.
Many US Mooney pilot are happy with their bladders. The downside is that you'll loose quite a few very valuable pounds in useful load and the bladders also cost around $8k when I last checked. I'm not sure whether they are available locally and if not, they're going to set you back in the region of R80k just to get them here. IIRC, installation is about 50hrs :!: :shock: :shock:
WRT the sealant going bad as a result of tanks not being kept full, this is only applicable if your Mooney is kept outside in direct sun. The sealant doesn't go hard or dry out because of not being submerged in Avgas, but as a result of heat buildup inside the fuel tank.
My newly sealed tank is 100% leak free and as soon as I have funds available, I'm getting the other side done as well. I can definitely recommend SA Mooney. They know their way around Mooney's and they have successfully done this exercise a number of times. Good luck.
pieter001
Stall training
Closest Airfield: NZWN
Has thanked: 3 times
Re: Fuel tank leak
Unread post by pieter001 »
I hope my time is far off still...
Good luck, I'm keen to hear the outcome. Seems the stripping is a serious amount of work!
ZS-CBW Mooney M20E - Plane Jane -> Sadly she is no more
Building a Whisper X
TerryE
Re: Fuel tank leak
She is in at the moment, looks like at some point in the past the tank was patched, as there are 2 types on sealant in the tank, and some idiot at some point, has epoxied over the inspection hatches. So the stripping is a bitch :roll: :roll:
The other side is also leaking, and that one is leaking into the cabin (check the carpets in the back right corner, nice wet patch with a blue stain). So that one is now also being stripped.
I'm doing a full strip down and reseal, much moola :cry:
TerryE
Re: Fuel tank leak
Some Pics
Left wing stripping
All masked up
Lood
Re: Fuel tank leak
Hi Terry, I feel your pain, but when all is done, you'll be happy that you went all the way. If you don't mind, what stripper are you using :?: I went through an extremely time consuming exercise to try and find a chemical that actually works without success. In the end, my tank was stripped manually. This takes about 3 weeks and makes for the ;largest part of the total cost.
My right tank also leaked into the cockpit. There wasn't much evidence on the wing itself, but when filled to the top, the fuel would actually drip slowly from beneath the center of the cockpit floor. #-o
TerryE
Re: Fuel tank leak
I will ask what stripper they are using. My understanding is that at some point the tank was sealed over an existing seal. The chemical stripper seems to work on the top layer, but only softens the bottom layer and they are having to scrape this second layer.
She originally went in to have only the left wing tank done, but we filled the right tank as a double check -
This is what happened about 24 hours into the process - and when you think about the ignition sources under there - Strobe power unit, UC motor, UC floor repeater light, Aux fuel pump (which burned out in December :shock: )
:shock: :shock: :shock: Scared the Cr@p out of me :shock: :shock: :shock: took about 2 seconds to make the decision to do the right tank.
pieter001
Stall training
Re: Fuel tank leak
I need to check my right tank too, fuel just dissapears from it. The fuel strainer valve is certainly suspect, but I think the may be more than meets the eye...
TerryE
Re: Fuel tank leak
Check inside the cabin against the back seat on the right side wall - We found a blue stain next to the seat rail, and this hidden behind the carpet. what is interesting is that I didn't smell fumes in the cabin - it looks like it drains under the floor, and that the floor and carpets seem to isolate the fuel smell from the cabin.
We never refill before parking - so that before the next flight you can decide on the fuel upload vs cabin load - and this leak seems to only happen when the tank is full, so it does not show up on the preflight. I'm very glad we decided to check the other tank ...
TerryE
Re: Fuel tank leak
They are using "Turco 5351" for removal of polyurethane and epoxy surface coatings.
Lood
Re: Fuel tank leak
Thanks Terry.
flashfly
Re: Fuel tank leak
Unread post by flashfly »
Eish. Left wing is leaking. Maybe I need to take your advise and take it to SA Mooney Lood.
If you let something bother you, IT WILL BOTHER YOU!!!
Lood
Re: Fuel tank leak
Sorry to hear that FF. Unfortunately, there are no shortcuts once a tank starts leaking. All quick solutions are only temporary.
A complete strip and reseal is the only way. I can fill both my tanks until they're about to overflow and they will keep that level indefinitely. If you do the major stripping yourself, it will save you you at least R15k.
andrem
Has thanked: 29 times
Been thanked: 45 times
Re: Fuel tank leak
Unread post by andrem »
Hi Nick,
Sorry to hear about that! Mine was completely stripped and sealed last year too - both tanks. I witnessed some of the work being done and can tell you that shortcuts should be avoided - having fuel leaking where exhaust gasses are blowing is no joke.
You can also try Eric Cook down towards Cape Town and make a holiday of it ;-). Although I suppose can be said of SA Mooney in East London.
Chimsoro
Airborne from Unmanned field
Has thanked: 19 times
Been thanked: 10 times
Re: Fuel tank leak
Unread post by Chimsoro »
SA Mooney,,,for a good job..the best
Return to “Mooney”
